Short block questions
Old Oct 19, 2009 | 06:22 PM
SpeedDensityZ's Avatar
Default Short block questions
Well, some of you know I trashed my AI 383 setup. I found an entire engine out of a caprice wagon for a really good price with 70,000 miles on it. Since money is pretty tight I'm going to do a stock short block with my AI heads. When it comes to the bottom end what is different? Can I put all my stuff like the balancer, crank hub (for camaro), on this motor. What will interchange and what will not?
-Thanks
Old Oct 19, 2009 | 06:47 PM
96capricemgr's Avatar
The shortblock is the same.
You might consider using the Caprice vented opti cover if you ahven't swapped to that already.
As you said use your hub.
Old Oct 19, 2009 | 07:16 PM
fuzzyjk's Avatar
-Thanks
I have a brand new LT1 long block (well Reman-ed) sitting in my garage collecting dust. $1000 plus shipping and its yours.
Old Oct 19, 2009 | 07:58 PM
LT1's Avatar
LT1
Will you be swapping the cam over? (not sure if your cam got trashed too)
Old Oct 24, 2009 | 04:45 PM
No, I bent the cam. I need AI to cut me a new custom grind for the different setup. I just need to save some more money so I can get all the parts I need together, it's probably going to be a few more months before the car is running. Thanks for the help guys.
Old Oct 24, 2009 | 05:08 PM
97Z28SS's Avatar
What happened to your 383?
Old Oct 25, 2009 | 08:35 AM
I broke the crank and the rest of the bottom end was history. I was running an Eagle Cast crank.
Old Oct 25, 2009 | 01:52 PM
old93camaro's Avatar
maccleny fl. whast your name man i may know you
 Michael S. Palmer
Old Oct 28, 2009 | 06:17 PM
Last name is Norkavage.
Old Oct 28, 2009 | 06:20 PM
robsquikz28's Avatar
you will be fine just transfer everything over.
