Ai 200cc CNC H/C Dyno, A4, 425rwhp
Sounds like you have it set up just right then for the 1/4 mile with those shift points and trap rpm. Are you going to leave us hanging or tell us what it ran? Congrats on the #s. Rick
Sorry about that, I missed it. Very nice. I too, am looking forward to some better 60's, but it's going to take a converter re-stall to get there. Best so far is a 1.59 and an average of 1.62s.
Very impressive!
I find those numbers extremely hard to believe and honestly don't really believe them but judging on your track times they do match up so I don't know what to think lol. You never see mild heads/cam LT1's on stock bottom ends put out 425rwhp through stalled autos. Those are numbers I have typically seen with folks running the same setup but through 6-speeds from Ai. I'm not hating at all I just feel like something is seriously being left out unless some tricks were performed that the average joe doesn't typically do which could squueze out some extra power. So, if I were to simply swap to Ai 200cc's and the same cam I would dyno 425rwhp which is 40rwhp more than my LE2's and 22x/23x cam? Doubtful as hell. Again, I'm not calling out just finding it hard to believe and assuming its legit that is extremely impressive and hats off to all involved!
Impressive, and the track numbers back up the HP, imagine that...
Guess AI isnt padding their numbers as implied by the clown stating "I'm not calling bs" when thats EXACTLY what he was doing... Lame.
Good work guys. I would be an ecstatically happy customer to have a B-body pulling low 11's with a stock ci mild build such as this, and I'm sure he is.
The track numbers are more impressive then the dyno numbers.
With the same 60' I was ET'ing 11.7 and trapping 115. Cam was probably extremely similar as well (custom 227/233).
To sum it up, those heads beat the hell out of my old local shop ported stockers
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Dont bend my statements out of context, I was very specific in what I said. I knew it was only a matter of time before some tool creeped in and started the attacks.
The numbers are outstanding. If you guys consider them typical, so be it. Props to AI.
I think this is exactly what most people miss. Straight from AI's OP message.
"It is an excellent example of what this setup will typically do when properly setup and tuned."
Ive read too many people who have build stroker engines making less than 425hp you can kind of get the idea why.
Very impressive!
#32
A question no one has asked is was the converter locked up or not? If so wouldn't this be the reason the numbers are so impressive since there would be no slip with the converter?
#34
lol, gotta love the senseless use of a double negative.
I meant to say every AI car I've seen dynoed has yet to put less than 400rwhp down.
and I'm pretty confident the 425rwhp was through a locked converter. a similar car with a loose unlocked converter would be lucky to put down 380rwhp. seen it in person actually.
#36
To my understanding most tuners leave it unlocked except in OD because a big hp car would shred the stall on the track if it locked.
If you have a nice triple disk converter that can take the abuse of locking you could lock it in 3rd to bring the trap rpms down, but locking it right off the line would negate the whole purpose of a stall.
And no way is locking the conv worth 45 hp, more like 20.
Jmho
Jmho
#37
Some cars can gain a bit by running unlocked then locking it on the top end, others can lose ET while gaining mph, and others still can show no difference at all. Only way to be sure is to test your particular combo.
#39
The converter was locked. That should be evident by observing the torque curve at low rpm's.
And to the questions about locked versus unlocked power numbers:
Experience with (2) Yank and (1) Vigilante converters I've had on the dyno showed ZERO statistical difference, I'm talking within 1 hp!, locked vs unlocked at peak hp. The lower the rpm, the more difference you will see.
With a less efficient converter than the two brands mentioned, I've seen a 25 hp difference at peak hp with the stock LT1 in the same car, peak power at 5250 rpm.
#40
Originally Posted by wrd1972
Obviously, these numbers are well above the frey for a 22x cam. I will fully admit that AI has some bad *** stuff, but at some point the numbers become so impressive that one should properly question them and IMHO, this is one of those cases. I am not calling BS here, but I think there is a wild card in this setup or measurement.
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
The fact of the matter is that there is not another ported GM LT1 head that has been better documented than our offerings. Moreover, when the majority of the highest HP and quickest/fastest NA cars run the same parts, it paints a pretty clear picture. Quite frankly, there is not a readily available head that is comparable or competitive in regards to performance or consistency. That has been the case for the better part of the past decade. Whether or not they represent a good value for an individual is subjective, but the potential and consistency has been documented to death. Some simply choose to ignore the data.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thank you very much, we do have a good many customers in KY.
Very impressive!
The one thing that has me scratching my head is the 22x cam that wants to be shifted at 6900 RPM and is trapping at 7100RPM. Hell if this were a M6, the dyno numbers would be freakishly high. Who wants to take a guess at those?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
It really needs to be said again, yes these are the typical results when the engine is properly tuned/adjusted. These #'s, like all of the outrageous #'s our customers work to put up, are all perfectly valid examples of the potential we make readily available to the market.
Glad you guys like it, thanks for the kind words.
