Car problem need help!!
Old Oct 21, 2009 | 04:12 AM
DatDude512's Avatar
Default Car problem need help!!
I have a 93 z28. When i start the car the check engine light come on. And when i'm driving and come up 2 a stop my car dies and i have 2 start it back up. But when i'm about 2 drive it hesitates 2 go. But when i get on the highway it drives normal. What could it be? I changed out the battery and got the altanator checked and it was good.
Old Oct 21, 2009 | 08:46 AM
fleetmgr's Avatar
Take it somewhere and have the codes read, see why you have an SES light...for starters.
Old Oct 21, 2009 | 11:06 AM
96blackta's Avatar
Sounds like it's running lean?
Old Oct 21, 2009 | 11:10 AM
RamAir95TA's Avatar
Just curious what makes you think it's running lean?
OP, have the codes read. That's why they are there.
Old Oct 21, 2009 | 11:16 AM
Murche's Avatar
you can pull the codes yourself on a 93
Check out shbox.com I'm certain the instructions on how to do so are there
Old Oct 21, 2009 | 01:24 PM
dlozSS's Avatar
Make sure your battery cables arent loose...it sounds like a problem I had but mine would pop right before it died when I let off on gas so I changed my fuel filter so might wana check that also
