braking after ls1 brake conversion
Old Oct 21, 2009 | 06:38 PM
baylove's Avatar
Default braking after ls1 brake conversion
hey i wanted to see what you guys braking was like after switching over to the ls1 brakes ?? is it worth it ?
Old Oct 21, 2009 | 06:41 PM
wrd1972's Avatar
Very much so. Stops a good bit quicker and is much less prone to fade out.
Old Oct 21, 2009 | 07:50 PM
96lt1m6's Avatar
I swapped my rears first and i noticed the front did not dive near as much
then on the following weekend i installed the fronts and then i was extremely appreciative of the new found stopping power.....bad part is i tested them sooo much i destroyed the factory crap rotors(warped them) now i will be stepping up a bit more for some high quality replacement componets.
Old Oct 21, 2009 | 08:03 PM
baylove's Avatar
o ok thanks guys im going outside to work on the car
Old Oct 22, 2009 | 09:34 AM
bigbirddriver94's Avatar
Im very satisfied with my ls1 swap. i would just reccomend getting rotors with a warranty and high quality pads right away.
Old Oct 22, 2009 | 10:11 AM
wrd1972's Avatar
I am in the process of replacing my front pads now. I have the napa safety stops (some type of Raybestos) and they squeal all the time and just dont feel as strong as they once did.
Suggestions?
Old Oct 22, 2009 | 03:12 PM
chavez885's Avatar
Suggestions?
Hawk ceramics if got the cash
http://www.byunspeed.com/product_inf...a195d47020afde
If too pricey, a buddy has the "Pro-Stop Ceramics" and they were very nice, no squeals and good braking. I believe pepboys is the only place that has those.
Old Oct 22, 2009 | 04:36 PM
baylove's Avatar
i wanted to go with slotted cross drilled rotors ??
Old Oct 22, 2009 | 05:30 PM
LT1WS6's Avatar
I swapped the fronts, as well as master cylinder... It did wonders for me
Old Oct 22, 2009 | 06:20 PM
baylove's Avatar
do i need to change the master cyclinder also ??
Old Oct 22, 2009 | 06:27 PM
01z's Avatar
01z
i never did a brake swap but i did a car swap and the brakes are wayyy better
Old Oct 22, 2009 | 10:39 PM
baylove's Avatar
well thats not in my budget
Old Oct 23, 2009 | 12:39 AM
chavez885's Avatar
You could if you wanted, its mainly aesthetic as they do not perform any better, probably worse.
No you do not, you'll bleed the brakes of course.
Old Oct 23, 2009 | 11:00 AM
baylove's Avatar
really ?
i thought the drilled rotors alloweed the rotors to cool faster after hard braking but i also heard they tend to crack drilled rotors look god also
yes i will blead the brakes o yea whats the bleeding sequence ?
