Valve locks question
Old Oct 21, 2009 | 08:04 PM
ADM's Avatar
ADM
Question Valve locks question
I ordered the 648-16 7* valve locks from Comp Cams to use with my beehives, but during a mis-hap with the over the head spring compressing tool, one lock broke in half and another gouged.
I did not order another set yet because I was told the stock valve locks are also 7*. However, upon comparing them visually, the lock is in a different position on the OEM and the CCs. If I even remember correctly, the CCs sit flush with the spring retainer while the OEMs stick out a little bit.
I am going to be running pro magnum self aligning rockers, and want to know if the buying OEM locks and using them will effect the rocker tabs from sitting correctly on the tip of the valve stem.
Old Oct 21, 2009 | 08:28 PM
Wicked94Z's Avatar
whats your installed height? i remember using +.05 locks to get 1.74, and that does not allow the use of SA rockers.
Old Oct 22, 2009 | 08:12 AM
ADM's Avatar
ADM
I just put the retainers on with the locks for a mock up, there is ample amounts of clearance between the tabs and the locks.
Old Oct 22, 2009 | 03:44 PM
Wicked94Z's Avatar
whats your installed height? thats the most important thing when installing valvesprings
Old Oct 22, 2009 | 06:58 PM
ADM's Avatar
ADM
I'm not sure to be honest, have not measured it. Neither do I have a spring micrometer or have I bothered getting one. I could use a vernier caliper and tell you what the installed hight is.
I just got the heads surfaced and a 3 angle valve job as well, so its most likely different than stock.
Old Oct 22, 2009 | 07:47 PM
Wicked94Z's Avatar
you need to check that man, bad things happen with valve float or broke springs
