victor efi manifold ! info needed.
if possible what do i use to plug the injector holes.
thanks.
uhhhh okay... yeah there won't be a problem running that intake with a carb but you do notice that it's scrunched down a bit in the runners compared to a normal Victor Jr and that is because it's designed to flow just air. Fuel takes up a good bit of volume in the runner so the runners have to be a bit bigger. and the bends smoother.... that intake is scrunched down cause it only flows air so they can sacrifice some intake runner size.
but i don't see why it wouldn't work however.... just don't know why you would buy that intake with injector holes and then try and run a carb....
...see no reason why you couldn't run a carb on that intake, but I would contact Edelbrock tech and get their opinion
