2 quick questions...
Also how good/bad are the power steering pumps on the LT1's? Are they hard to replace?
Sorry for all the questions, I'm learning/trying to learn everything I can. Thanks For all the help!
And no, its impossoble for that to "create pressure and break lines" since its not even part of the closed system during normal operation.
The overflow reservoir is above the seal of the radiator cap, and only exchanges coolant with the main system in the event the pressure goes higher than the cap is rated for.
What you need to do is pull the radiator cap (with the engine cold) and check the actual level in the radiator, and top it of if needed.
The worst that will happen from you overfilling the overflow is some coolant may end up on the ground at some point.
Your supposed to fill the radiator to the top, but nothing will happen if you over filled the "coolant reservoir", it will automatically come out when it gets hot.
Make sure to bleed the coolant system of air or the temp. gauge will bounce around and you'll have air pockets.
