ok big problem here....
Old Oct 31, 2009 | 01:37 AM
NSTIGATR's Avatar
UPDATE:
replaced the fuel pump with a new walbro today. cranked the motor and it wouldnt fire, finally fired... no. 5 header is cold. got fire, got pulse to injector,. guess after 3 years of sittin the injector is bad.
also oil pressure quit working. reading 0. shut motor down. had a brand new gauge on it. will put a new sensor on it tomorrow.
Old Oct 31, 2009 | 08:11 AM
old93camaro's Avatar
so is it fixed yet.....
Old Oct 31, 2009 | 04:42 PM
NSTIGATR's Avatar
ok got the car running.. fuel pressure issue.. there was a cut in the rubber line to the walbro pump, put a new rubber line on and its up to 40 psi.
replaced oil pressure sending unit, motor reading 65 psi. runs like a top now. thanks for the help.. now all i have to do is get this sjm line lock and abs delete hooked up. flaring lines is such a pita! especially when the tip of the die breaks.
one new thing however... the fuel gauge is pegged above full. it was working after i put the fuel sending unit in the car though. checked the ground beside the drivers seat and its good. any ideas?
