ok big problem here....
Old Oct 24, 2009 | 03:45 AM
NSTIGATR's Avatar
Default ok big problem here....
just finished the install on my 383 lt1. m-6. its in a 94 Z...
when i tried to crank it the first time it just clicks under the dash on a relay and under the hood. the vats is working properly because the security light goes out after 4 seconds. horns, lights all function. fuel pump does not prime. any ideas im stumped.
a few other things done while motor was out... removed both airbags, and all HVAC, power steering, a/c comp. relocated alternator down low.
Old Oct 24, 2009 | 08:33 AM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
you need to figure out what relay is clicking. do you know which one it is? if your fuel pump isnt priming then i would say you have a fuel issue. either your pump isnt getting the sign to turn on. or you have a bad pump. that would be the first place i looked. check the relay, and then look over your fuel system
Old Oct 24, 2009 | 12:32 PM
NSTIGATR's Avatar
Would any of those fuel issues cause the motor to not turn over? The motor will not turn over.
Old Oct 24, 2009 | 01:02 PM
SS RRR's Avatar
Village Troll
Battery may be no good. It doesn't take very much voltage for lights/horn to work. Put a volt meter on your battery and check to see if it's any good. Have someone try to start the engine while the volt meter is on the battery and see if there is a significant voltage drop. I take it the battery sat while the swap took place? You can also take it to Autozone and have it load tested for free.
Old Oct 24, 2009 | 02:26 PM
AChotrod's Avatar
Originally Posted by ss rrr
battery may be no good. It doesn't take very much voltage for lights/horn to work. Put a volt meter on your battery and check to see if it's any good. Have someone try to start the engine while the volt meter is on the battery and see if there is a significant voltage drop. I take it the battery sat while the swap took place? You can also take it to autozone and have it load tested for free.
x2!!!
Old Oct 24, 2009 | 06:28 PM
ooo **** i didnt even notice the just clicking part. yet definately if its really dead it will click just once. if its only lacking a little itll just click repeated. the best way to explain it. its lights and all take about 2-3 volts to turn on. not much at all. and maybe 4-5 volts to click the starter solenoid. but it wont have enough to crank the motor over. but yea definately check your battery. good call SS RRR
Old Oct 24, 2009 | 08:16 PM
n2ocamaro's Avatar
This happened to me when I went to fire my stroker for the first time. It turned out I had the ground to the starter solenoid in the wrong place. I put in on the block and fired right up. Just something to check.
Old Oct 24, 2009 | 09:03 PM
robsquikz28's Avatar
check ur batt first then then respond back if no start!
Old Oct 25, 2009 | 12:45 AM
NSTIGATR's Avatar
Will do.. Out of town till monday. What's that bout the ground for the starter solenoid to the block? I've got the hot off the battery and the purple switch wire and a black and white wire with the purple switch wire
Old Oct 25, 2009 | 01:03 AM
94BlueZ28's Avatar
Negative on this, The motor would still turn over! Actually when I fired mine up for the 1st time I primed my engine while the fuel pump was disco'd and the coil wire off.. You say u removed the airbag's. I had an issue with mine as well. Make sure you install all of the relays back in off the bracket that holds the passenger side airbag in...There are like 4 little relays with the VATS module attached to the bracket. Mine fired right up after plugging them back in!
Old Oct 25, 2009 | 02:16 AM
Wicked94Z's Avatar
might be the tdr... mine mysteriously stopped working when i swapped motors
Old Oct 25, 2009 | 07:52 AM
n2ocamaro's Avatar
I think the black and white wire is supposed to be grounded. I will go look at my car later and check.
Old Oct 25, 2009 | 05:52 PM
NSTIGATR's Avatar
So can someone tell me where the black and white wire goes that's the in the same loom as the purple wire....currently is on the starter aolenoid with the purple wire
Old Oct 25, 2009 | 05:57 PM
93v8clone's Avatar
ground the black and white wire ,purple is the trigger wire
Old Oct 25, 2009 | 06:05 PM
NSTIGATR's Avatar
Where to? Block or on the frame? Been so long I can't remember where it went just that its the same length and loom as purple wire
Old Oct 25, 2009 | 06:07 PM
93v8clone's Avatar
i did the block ,if i remeber right it was near the dip stick tube where it goes"for the motor oil
Old Oct 25, 2009 | 06:12 PM
NSTIGATR's Avatar
Will fix that and check the battery when I get back home tomm...thanks so much for the help
Old Oct 25, 2009 | 06:23 PM
nik1703's Avatar
Definitely your battery, I had the same problem last year. Clicking noise was driving me crazy, then I jumped it and it fired right up. I'm assuming your car has been sitting for a while - you'll probably need to charge the battery for a good 15 minutes before youll be able to start it. Or just swap in a new battery
Old Oct 25, 2009 | 06:24 PM
93v8clone's Avatar
isnt that what we here for ? that and talkin mad **** about how we all got 10 sec rides lolol
Old Oct 26, 2009 | 05:40 PM
NSTIGATR's Avatar
ok black white wire now grounded and motor is spinning over like it should... now im not getting fuel. when i turn the key on you cannot hear the fuel pump coming on. also fuel gauge is pegged above fuel and wasnt like this the other day...
yanked the fuel pump after checkin for power at the plug by the tank. yup fuel pump is gone. orderin another walbro tomorrow.
