Questions about the LT4 cam kit
So i have heard some people having problems with the poly locks backing off that come with that kit... should i get new ones? if so which ones? I will be getting Trickflow hardened pushrods (TFS-21407200 is the correct part number from summit correct?), but to make sure, i do not need to get guide plates correct? Ill be getting a new timing chain kit, i already have a new opti, i will probably get a EWP. anything else you can think of? im not 100% sure if its coming with lifters or not. the car has 115,xxx miles. should i get new ones?
I had no problems with the poly locks that came with the kit, I believe they're crane.
Before you order your pushrods, order a new set of ls7 lifters, then measure your pushrod length, then order the right push rods.
I still run the stock waterpump, but if your set on an electric you mise well buy a cloyes double roller.
As long as they're the bowtie SA RR's you do not need guide plates.
No i'm not set on the electric waterpump. what timing chain set should i get just for a nice stock replacement? If i decide on a EWP whats the part number or a better description of the timing set? Summit had 4-5 of them
The LT4 package comes with lift limited rockers and insufficient springs, they are OK with LT4 heads because those have special liteweight valves.
Oh and guideplates should only be used with non-sa rockers, the "kit" ones are SA.
Not the screaming deal folks MISTAKE it for.
But hey whatever floats your boat.
60 - 2.004
1000 ft - 11.03 @ 97.6 mph
I could have gotten into the 10's with it but my car wouldn't shift into 3rd at WOT so I was pegged out on the limiter in 2nd about the 800 ft mark. And that was with street tires. Oh well, still had fun. With a good stall (and a new tranny) and some 3.73's I hope to get deep into the 10's (1000 ft). Haven't had a chance to run the 1/4 yet so we'll see next year.
Ok, so they have a higher rpm handling capacity, not exactly gonna be spinning a hotcam to 7000 are you?
That and the fact that they just complicate things by requiring a different pushrod length, I wouldnt bother.
Whatever floats your boat though, some people like throwing money away because it makes them "feel good".
I run a cam with lobes a hell of a lot more aggressive than the hotcam and its fine on the stock lifters.
.02
