reusing engine bearing
Old Oct 25, 2009 | 06:21 PM
chevyjeff59401's Avatar
Default reusing engine bearing
I was wondering what the correct way to clean engine bearings would be. The engine was assembled anfd installed in car with no intake. when I bought the car I took it apart to clean mild water damage to lifter valley and inspect. I have cleaned all rust and hottanked engine and am working on reassembly. I pitched cam bearings but am wanting to reuse main and rod bearings. They are all still matched up to where they were in engine just need to get oil and assembly lube cleaned up. Thanks Jeff
Old Oct 25, 2009 | 06:25 PM
93v8clone's Avatar
change em ,they are cheaper than a new rotating assembly ,that and stock bearings are junk
Old Oct 25, 2009 | 06:31 PM
the_merv's Avatar
Veteran: Air Force
Never.
Old Oct 25, 2009 | 06:37 PM
They are clevite hseries bearings and its never been started. Does that change anything or should i just chuckem. Thanks for the fast replies. Im on a tight budget cause im adhd and get too many projects going at once. Thanks again guys
Old Oct 25, 2009 | 06:47 PM
AChotrod's Avatar
If they are new I would reuse them. Even if they were somewhat new I would.
Now the best possible thing to do would polish the crank and get new ones
Old Oct 25, 2009 | 09:19 PM
fergymoto's Avatar
Just wipe them with a lint free rag and acetone as long as there is no corrosion done to them.
Old Oct 26, 2009 | 12:21 AM
the_merv's Avatar
Veteran: Air Force
That new info helps out..since the Engine was never ran it makes it different..I would run them, they have never been used.
Old Oct 26, 2009 | 10:58 AM
Yeah I got to rambling in my first post and forgot to add the important information. Thanks guys it should save me a lil money. Jeff
Old Oct 26, 2009 | 11:01 AM
FASTFATBOY's Avatar
I have reused engine bearings in mine with 1500 miles on them.
Clean them, if any scuffs on them use Scotchbrite and smoothe the marks down. As long as the marks dont catch a fingernail leave them alone.
Old Oct 26, 2009 | 12:13 PM
fergymoto's Avatar
I reused bearings with 90k miles on them before in one of my own stock short blocks. They were in nice shape
