cammed lt1 on spray today
Old Oct 31, 2009 | 01:48 AM
  #41
daniel6718's Avatar
Originally Posted by robsquikz28
What octane are you running?
shell 93 and mail order tune
Old Oct 31, 2009 | 01:52 AM
  #42
CamaroRacing12's Avatar
texans. its always texas boys who do it big lol
Old Oct 31, 2009 | 02:24 AM
  #43
BSmiff's Avatar
If you only knew. My dads car(sig car) just got shook down tonight with its first passes in 8 months........lets just say went very well.
Old Oct 31, 2009 | 03:50 PM
  #44
robsquikz28's Avatar
and ur spraying thru the gears too right?
Old Oct 31, 2009 | 04:27 PM
  #45
BizZzatch350's Avatar
Moderator
Mike Graham (sp) was running 10.8s in a 95 Z28 back in the late 1990s, car had maybe a 150 shot, Comp 224/236/114 cam, 2800 Vigi, usual bolt ons and wasn't a tin can. Frans96SS on here ran 11.0@12x, Th400, 9 inch, long tubes, 200 shot other wise a dead stock long block. If you compare it to Frans or Mikes car, the times make sense, wouldnt be so quick to call b.s. Fastest stock short block LT1 is BigKevC5s old 97 Z28, 9.7@13x.
Old Oct 31, 2009 | 09:02 PM
  #46
daniel6718's Avatar
yepp...well the window it set at the shift point rpm
yessir..and good info...we got our goal..we gota lose some weight
Old Oct 31, 2009 | 09:46 PM
  #47
btw what kit do you have?
Old Oct 31, 2009 | 10:31 PM
  #48
Moderator
They say it in the first post, NX nozzle, didnt say if it was a single or dual nozzle kit. We had an NX dual nozzle on stock headed 355 30th Anniv Z28, six speed car, 3.42s. Car was a turd on motor, but ran it's *** off on gas. This post needs to be a sticky because it's basically a staple Chicago/Texas LT1 set up. Keep it simple as hell on motor, nothing fancy just make it work good and then spray the ever living **** out of it, thats how you hurt local LS1 feelings and go fast
Old Oct 31, 2009 | 10:55 PM
  #49
BSmiff's Avatar
Why should this be a sticky? Then there would be no innovation and every damn LT1 would be the same. That would be a horrible idea. The 3 threads in this sub forum that should be stickies are the bolt-on record thread, beaflags weight reduction thread, and the fastest lt1 thread.
Old Nov 1, 2009 | 12:58 AM
  #50
lol i agree, even though this is impressive i dont think it should be a sticky lol
Old Nov 1, 2009 | 03:13 PM
  #51
daniel6718's Avatar
lol...its a single nozzel...and were goana go faster soon...da just keeps dropping....i dont consider us to be spraying the **** outa it...its a reliable setup as of now...mostly its the good supporting mods that make it that fast
Old Nov 1, 2009 | 03:20 PM
  #52
BSmiff's Avatar
Yall getting that englishtown type DA in dallas right now. Super weird.
Old Nov 1, 2009 | 04:06 PM
  #53
s346k's Avatar
i don't think it's questionable at all. the key to turning at ET is setup. i see the car easily making the power to go 102 in the 1/8, but this dude spent the time getting his **** to hook. a lot can be done when you're putting all of the power down and not spinning it away.
go race at some 1/8 mile tracks. see what those bracket cars run. they always have a stellar ET coupled with a mediocre trap speed. there is a lot to be learned from the hillbilly 1/8 mile tracks across the us.
Old Nov 1, 2009 | 05:01 PM
  #54
daniel6718's Avatar
no shez...but were not going tonite...da should be 400-700
yessir...weve got a small stall and 10 bolt so it wont 60 much better...its actually meant for 1/4 racing its not high geared or big stalled...
Old Nov 2, 2009 | 09:25 AM
  #55
StangeatinZ28's Avatar
Originally Posted by SPRAYED Z
so you either have heads that are ported or ur spraying atleast a 200 shot even to achieve that 1.48 60ft...something is fishy about ur car and ur not tellin much??
****, i pulled a 1.5 60 with just boltons and a 150 shot. and the car went 11.67. no cam or headwork
Old Nov 2, 2009 | 10:10 AM
  #56
BSmiff's Avatar
Definately believable. The cam and tuning probably make that difference between your et and the LMP cars et.
Old Jun 20, 2010 | 03:25 AM
  #57
daniel6718's Avatar
back onto this car...the DA sux and we wont be doing anything special anytime soon because of the weather but we did swap into it a th400 and vigilante 3600 stall(we believe) its way too tight on motor and no the car goes 8.0 at 85 on motor...
the old trans from Frank at CPT broke the output shaft on a warm up motor pass
theres a local 7.0 class we run in now and we dialed the car in on a 125 shot to go a 7.0...tonite we tested and went a 6.99, then had a by, one easy pass i just stayed in front of the guy, then our last pass we had slowed the car down because the track was cooling and we had gone a .99,
we went a
.58
7.09 @98
other guy went a
.65
7.01 @100 and won by .0006 i believe
so anyways the car now runs 6.99 on a 125 thats still detuned
its got a .85-.92 in it on 125 and who knows with the 200 again
the stall loves nitrous...picked up 1.01 and 14mph easily on 125 in the 1/8
Old Jun 20, 2010 | 06:12 AM
  #58
FASTFATBOY's Avatar
The stock shortblock record is in the 9's for an LT1, its a white 3rd gen Trans AM, he is on this board.
Old Jun 20, 2010 | 12:07 PM
  #59
Moderator
Yeah, he has it now, but not at the time this post was first posted.
Old Jun 20, 2010 | 07:00 PM
  #60
BSmiff's Avatar
Glad to see this car back out Daniel
