First time on a dyno (mostly stock)
Old Oct 26, 2009 | 02:42 PM
big_bird_93's Avatar
Default First time on a dyno (mostly stock)
Local shop had a dyno day on saturday so i decided to go and see where my car stands. First pull was the best. 282hp/329tq. The second pull was 280hp/323tq and then the third pull was only to about 4800 and backfired a couple times 255hp/310tq. Needs a tune up bad. Any suggestions after a tune up on the cheapest way to break 300?
Old Oct 26, 2009 | 03:57 PM
slomarao's Avatar
good numbers.
Old Oct 26, 2009 | 04:00 PM
96lt1m6's Avatar
longtubes
1.6 roller rockers will bust the 300 mark
my friend has a '93z A4,longtubes,true duals,pcm4less chip and 160* stat
he busted off 282hp 317tq...your m6 will make more!
Old Oct 26, 2009 | 07:33 PM
YngBird's Avatar
Thats pretty good man. Mine was 285/323 with shorties and borla.
Old Oct 27, 2009 | 07:21 AM
wrd1972's Avatar
What were these numbers corrected to? Thats very high for a stock motor with only a catback and a straight shot intake.
Old Oct 27, 2009 | 08:22 AM
Nice car. Where did you find that your car is 1 of 8? I cant find color breakdowns for my car.
Old Oct 27, 2009 | 08:23 AM
Not sure how to find this...
Old Oct 27, 2009 | 08:24 AM
whytryz28's Avatar
That is pretty high, intake and catback is all?
Old Oct 27, 2009 | 08:25 AM
whytryz28's Avatar
You guys must have a generous dyno haha
Old Oct 27, 2009 | 09:10 AM
pretty much. also has a larger y pipe (3") and a hi flow cat. So its 3" from the manifolds back. Not sure if it makes a diff on how the power is transferred but it has an aluminum ds and 3.73s. but those have no effect on power, do they?
I guess so. lol. I dont know **** about ****. The graph is in no way smooth. Ill try to load it up in a lil while. It looks bad. Very wavy. So most likely the 282 came from a spike. Peak hp does'nt mean much, Its about consistency from what i understand.. (?)
Either way i wanna get some longtubes and do a few more bolt-ons. i.e. tb bypass, airfoil, and ewp. Then look into head and cam pkgs.. Any problems seen with this route?
Old Oct 27, 2009 | 09:16 AM
1nicez28's Avatar
my 6spd lt1 camaro put down 262whp/285wtq with just hollowed cats.
Installed long tubes, ory, borla cat back, cai, and a mail order and it put down 290whp/325wtq so your numbers aren't to bad from what i see.
Old Oct 27, 2009 | 09:23 AM
wrd1972's Avatar
262/285 is just slightly above average spot on for a stock M6 LT1. 260/280 IMHO is average.
If you had spikes with a M6 car on the dyno, something is wrong with the car or dyno. M6's dyno very smooth compared to A4's. Just post the graph and we will comment and ask the dyno operator if the numbers were corrected. Ideally, you want to post SAE corrected numbers for a fair comparison and comment.
Old Oct 27, 2009 | 09:25 AM
1993 z28 f1's Avatar
Hey:
93s always make more power... its that speed density thing LOL.
Pretty good stock numbers, depending on where you live, buy a good set of LPP race long tubes, when they come out , dual hi flow cats and get a tune chip from Madtuner or Pcmforless deleting air and egr and you'll be tearing the track up. It really cleans up the engine bay on 93s, but deleting air and egr has no hi perf value other than looks and ease of getting to things.
Tune chip, 160 t stat, Ewp, 1.7 7/16" nsa rockers with supporting springs, hardened guide plates, 7/16" studs, and correctly measured 5/16" hardened push rods, with the LTs and dual cats should get you over 300, on that dyno with those readings.
Dub
When In Doubt Do Without
Old Oct 27, 2009 | 09:58 AM
Old Oct 27, 2009 | 10:04 AM
I know it is either fuel or spark. Im gonna start with the basics. Plugs, wires, and Opti. Just for peace of mind. Then i need to check the fuel pressure and work from there..
Old Oct 27, 2009 | 12:39 PM
MonmouthCtyLS7's Avatar
Good Numbers for a LT1!
Old Oct 27, 2009 | 12:50 PM
wrd1972's Avatar
According to the graph posted, the numbers were corrected to SAE. With respect, the torque numbers (323RWTQ) are stupid high given the mods you have and that is also taking into account 1993 speed density. That dyno seems extremely happy given the details provided plus the possibility that the tune is not even optimized.
Now about the spike problem. Seems like ignition to me and you are on the right track. Get some MSD super conductor wires and delco plugs.
Old Oct 27, 2009 | 03:29 PM
YngBird's Avatar
The previous owner found them. Do you have cloth interior?
Old Oct 27, 2009 | 04:20 PM
whytryz28's Avatar
Originally Posted by 1993 z28 f1
Hey:
Sweet, guess I better get my **** dyno'd before it breaks haha.
Old Oct 27, 2009 | 06:20 PM
Nope. Charcoal or Ebony Leather.
