lt1 exhaust manifold
the LT1 is still considered a smallblock so they should just bolt up perfect
http://www.summitracing.com/parts/SUM-G9060#
$100 bucks cant bet that hope this helps
OP, keep in mind this is not a common plug found at your local hardware store - it is automotive-specific.
Home depot can probably order them for you, you can measure them out and try to put a 18mm wrenc over it and if it fits then you know its a 18 or a 22mm...then order the one you need.
