low coolant light?
Old Oct 26, 2009 | 07:21 PM
LT1T/A's Avatar
Default low coolant light?
My low coolant light is staying illuminated the whole duration the car is on and this has been going on for the past 2 months. The coolant is full, the temp stays real low (around 160-170), and the water pump and thermostat are both only about 4 months old. Any idea why?
Old Oct 26, 2009 | 07:22 PM
SeanT/A's Avatar
Check the conection on the sensor on the tank.
Old Oct 26, 2009 | 07:23 PM
RamAir95TA's Avatar
Your low coolant sensor probably crapped out. It's a very common problem. If you unplug the sensor, the light will stay off (located on the passenger side of the radiator, about 1/3 of the way down).
Or you can replace it.
Old Oct 26, 2009 | 07:26 PM
95_transam_lt1's Avatar
the sensor might just be dirty, drain the coolant, remove the sensor clean it and replace. It could be caused by dexcool gumming it up. or oil
Old Oct 26, 2009 | 07:28 PM
LT1T/A's Avatar
Wow quick responses. Thanks guys.
Old Oct 26, 2009 | 08:10 PM
95zpro's Avatar
As I recall that sensor was a little on the pricey side; $40.
Old Oct 26, 2009 | 08:18 PM
myltwon's Avatar
**** that sensor, just unplug that bitch
Old Oct 26, 2009 | 11:36 PM
~BuMps AloT~'s Avatar
Ya mine went out about 6 months ago. I just got a new sensor from autozone. 30 bucks i think....
Old Oct 27, 2009 | 09:43 AM
86formula's Avatar
15 from auto zone for me a couple weeks ago
Old Oct 27, 2009 | 10:54 AM
wrd1972's Avatar
Wow. Might have to splurge and replace mine which has been unplugged for umm...forever.
Old Oct 27, 2009 | 11:53 AM
4thGenRS's Avatar
OK, I have a question on this too.
About a month ago I changed the coolant and the low level sensor since my light was on (1995 Z28). Light stayed off about a week and now it's back on again. Coolant is fresh and full with a brand new sensor... can't understand why it decided to come on again?
I guess I can take the battery out and check the connection again but that is probably the last thing I can think of to do. Any other suggestions?
Old Oct 27, 2009 | 12:52 PM
wrd1972's Avatar
These coolant low sensors are very problematic whether new or used and have the background history to prove it.
Nothing else to say.
Old Oct 27, 2009 | 01:19 PM
slow96z's Avatar
Yeah, assume that if the factory one is crap and has to be unplugged the aftermarket ones aren't going to be much better. I'd do the unplug it and never think about it again mod, cheap and lasts...
Old Oct 30, 2009 | 10:10 PM
MasterTomos's Avatar
yup mine goes out annually too...lol
replaced it about a month ago...
