Custom grind Solid cam question?
Old Oct 27, 2009 | 04:17 PM
Yousif Q8's Avatar
Default Custom grind Solid cam question?
Hi there,
I just find that a custom grind solid cam 590/588lift 230/243duration 115 lobe intake ceter line 115 so what do you think guys it's ok for my setup or should i go with another cam
the setup:
383 stroker(9.5 compression)
Porting lt4 heads (2.02/1.6)
Procharge F1R custom bracket (air to water custom intercooler)
any opinions
Yousif
Old Oct 27, 2009 | 05:35 PM
ThreeHonks's Avatar
who spec'd the cam?
Old Oct 27, 2009 | 06:34 PM
myltwon's Avatar
seems pretty mild for a SR grind
what's the advertised duration?
Old Oct 27, 2009 | 07:15 PM
wht97ws6ta's Avatar
Not a bad piece for your application, nor is it optimal. Its fairly conservative IMO.
Old Oct 28, 2009 | 06:06 PM
Yousif Q8's Avatar
Originally Posted by ThreeHonks
who spec'd the cam?
comp cams
Old Oct 28, 2009 | 06:09 PM
Yousif Q8's Avatar
at .050 230/243
Old Oct 28, 2009 | 06:13 PM
Yousif Q8's Avatar
thanks guys for replies
but i want the best cam for my application,so any one can help me to find better than that cam??
thanks
Old Oct 28, 2009 | 07:13 PM
ThreeHonks's Avatar
yeah i was asking becasue its very mild. I would call or email Lloyd Elliott. He will spec one for you
Old Oct 28, 2009 | 07:33 PM
myltwon's Avatar
thanks
actually I was looking for the advertised duration numbers, that's @ .050"
def call up lloyd elliott @ www.elliottsportworks.com, pretty much any "custom" by comp is just an salesmen pointing at a page in a catalog that offers pretty generic grinds. hardly ever will you talk to anyone at comp that isn't just reading off a list with any real knowledge
Old Oct 28, 2009 | 11:14 PM
Wooshie's Avatar
There are hydraulic grinds that are more agressive than that. I agree that the guy from Comp was a moron. Talk to Lloyd or any reputable cam grinder to get hooked up.
Old Oct 29, 2009 | 08:57 AM
James Montigny's Avatar
Hi there,
Much too small to make the most of your 383.
Keep in mind that with S/R, the valve "see's" about 10* less than it would with a similarly speced H/R
so what you have there is only slightly bigger than a hotcam.
Talk to Lloyd, let him know how you intend to use the car and what you want it to feel like, he'll take care of you.
I really don't see a point in running an S/R cam if it's going to be that mild.
Old Oct 29, 2009 | 02:52 PM
Z-RATED94's Avatar
SpeedInc. does a lot of boosted cars. Maybe give them a call to see what they say. I could be wrong, but with boost in the equation I don't think the cam has to be real aggressive.
Old Oct 29, 2009 | 09:11 PM
wht97ws6ta's Avatar
I think something around 242 @.050 on intake and 250 @.050 on the exh on 114 LSA would definitly put somemore steam in upstairs. Its gonna make decent torque down low with the supercharger, so its not going to lose alot of lowend torque from the bigger lobes.
Old Oct 29, 2009 | 11:32 PM
Speedracer2j's Avatar
I have a custom grind solid roller from comp, actually, here is the part number and the specs...
Intake 244 @ .050 duration, .615 lift
Exhaust 250 @ .050 duration, .630 lift
Lobe separation is 112
07-0009/4121/4004/SR112
