ls1 strokers ?
Old Oct 31, 2009 | 06:26 PM
9D4Z28's Avatar
Question ls1 strokers ?
whats the reason you will always see lt1s stroked and very rarely see ls1s stroked ? is it because the ls1s dont need to be stroked to get real power out of them ?
Old Oct 31, 2009 | 06:35 PM
94LTZ's Avatar
I think yo have this in the wrong section. Shouldn't this be in the LS1 engine.
Old Oct 31, 2009 | 07:05 PM
myltwon's Avatar
because most guys that spend money and want more cubes in a gen3+ motor just get an iron LQ9/4 which is stronger and allows more displacement. also the blocks are cheaper too I believe
Old Oct 31, 2009 | 09:31 PM
Kmaroman's Avatar
Not 100% but if i remember corectly the ls1 is a sleeved block while the lt1 i believe is called a dry sleeve or something. Anyways when a block is sleeved it doesn't wear out like an older block where you would have to bore it over to fix any imperfections. A wet sleeve block has what you call sleeves in the blocks which you just take out and replace after so many miles rather boring the block over some. Hence you can't bore the ls1 as easily over as an older non sleeved block
Old Oct 31, 2009 | 10:34 PM
gregrob's Avatar
No...
Old Oct 31, 2009 | 10:56 PM
BizZzatch350's Avatar
Moderator
They build strokers like crazy, I see more stroker LS1s then I do LT1s.
