$300 for mods
Old Nov 3, 2009 | 02:08 AM
hawk584's Avatar
300$'s? put that money in the bank and let it build up..... or spend it on gas
Old Nov 3, 2009 | 09:45 AM
cgEvan's Avatar
Thanks for the advice, but I have gas money and investing money, this is play money.
Old Nov 3, 2009 | 09:50 AM
RamAir95TA's Avatar
I think what he's saying is that $300 is (in this hobby) a reasonably small sum, so save it and put it towards something bigger (cam swap, etc.).
Old Nov 3, 2009 | 11:09 AM
cgEvan's Avatar
I can understand that, I'd just rather touch 12's with small bolt-ons (I use the car daily and travel around Ga quite often in it). Luckily, bolt-ons seems to be cheap, hence my $300 thread
I ordered the "cable loan, power tune" from lt1pcmtuning.com. It's $100 and he'll fine tune my car, as many times as he can, in a week. So $200 left. I think I'll build the "over the radiator" intake as well.
Old Nov 3, 2009 | 12:39 PM
gregrob's Avatar
Do an LS1 lid! Would still have 150ish left over.
Then do LCA relo brackets and LCA's.
Old Nov 3, 2009 | 12:54 PM
am_muscl's Avatar
I hate to do a thread jacking here but I'm kind of in a similar situation. most of my mods are listed in my sig but to go over everything...
-Pacesetter Longtubes and ORY
-K&N Intake
-Custom ground cam w/ valvetrain upgrades
-Madz28 tune
-Nitto 555r's
-UMI LCA'S, PHB, and SFC's
-3.73 gears
-Weight reduction (back seats, passenger seat)
-BMR STB
-Stock heads, intake, and bottom end with ~140K miles
I don't plan on getting rid of my A/C or power steering quite yet so I don't want any delet pulleys or anything and I also don't want to spray the car right now either.
I'm wondering what else I should really do and I'm in the same boat as the OP I have about $300 to play with if that will get me anything.
Old Nov 3, 2009 | 03:37 PM
cgEvan's Avatar
-K&N Intake
-Madz28 tune
-Nitto 555r's
-3.73 gears
-BMR STB
This might sound dumb, but if you can't think of anymore mods (I could, just couldn't decide), then always look at maintenance. Is your ignition recently replaced? New plugs, wires, opti, fuel filter, injectors cleaned, maybe a seafoam, etc.
If all that is up to date, look into an intake manifold/throttle body!
Old Nov 3, 2009 | 03:42 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Didn't know that. You think running a stock MAF with a tune compared to the Granatelli with a tune would be better?
That's what I've heard. So if you're getting a tune, I would go back to the stock MAF.
Old Nov 3, 2009 | 03:44 PM
RamAir95TA's Avatar
What intake manifold would you recommend? For his application, stock is MORE than enough. A bigger throttle body on a bolt-on car also might not be worth the money compared to a tune, suspension, lid/CAI, etc.
JMO.
Old Nov 3, 2009 | 03:51 PM
legendarysouls's Avatar
shouldnt you get the tune after u spent the other 200$$
BTW: TB or intake
Old Nov 3, 2009 | 03:55 PM
one fast zo6's Avatar
a good set of 1.6 roller rocker arms, valve springs, pushrods.
goodluck
Old Nov 4, 2009 | 01:09 PM
  #32
quik95lt1's Avatar
Tune would benifit alot I would save the rest of your money and eventually stick a bigger bump stick in it, that is the best way to make more hp/$.
Old Nov 4, 2009 | 04:00 PM
  #33
cgEvan's Avatar
Tune on order and I think the next step is spray to see what she'll do
