How to drain gas tank
Old Nov 3, 2009 | 03:14 PM
x Wild Bill x's Avatar
Default How to drain gas tank
Hey guys, quick question, how do you bypass the fuel pump relay so that it will stay on all the time? I need to drain my gas tank when I get home because I think my gas has gone bad. I know where it is located, just which pins to jump or w/e.
Thanks,
Bill
Old Nov 3, 2009 | 03:17 PM
RamAir95TA's Avatar
Look on the passenger side of the engine compartment in the back corner just front of the PCM. In the bundle of wires for the cooling fans, you'll find a fuel pump prime connector (one loose wire with a connector, will be red for 96+, orange for 93-95). Jumping 12V to this lead will kick-start the pump. Disconnect the line off of the fuel filter and empty. Voila.
Old Nov 3, 2009 | 03:58 PM
Alright cool, I thought that would only turn the pump on to "prime" it, the usual 2-3 sec. as it is the fuel pump prime wire lol. I was going to try it anyways, glad to know it works :-)
Thanks,
Bill
