Fresh rebuild, no start
Thanks,
Bill
Bill
just some ideas to think about.
Thanks,
Bill
Thanks,
Bill
Thanks,
Bill
What I need to know is dot to dot okay, or should I take of the timing chain and go 12 to 12?
Thanks,
Bill
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Another one i've seen is build up in the opti harness
Thanks,
Bill
Ebay Store
I had finished my build, everything was on right, double checked all my wiring and my ignition cables 3 times. It would only pop a few times.
I undid the rocker arm nuts and re-adjusted the valve lash. Fired up from the moment it cranked over. When I had removed the lifters, I put them on a piece of cardboard upside down to bleed out all the dirty oil out of them, and cleaned them up, then soaked them for a day in fresh oil. However, its not enough to have pressure in them. When I went to start the engine, the valves were leaking compression once the lifters got pumped up.
Give it a try, it might just be that.
Thanks,
Bill
Ohh and juced, I had already drained the tank thinking it could be bad gas lol
Good to hear it was the lash.
Ebay Store
