going for an opti change record
Old Nov 9, 2009 | 03:37 PM
rat93's Avatar
Originally Posted by leadfoot4
If you mean when you install the new wires in the loom behind the PS pump, there's only one sure-fire way that I know of......The factory shop manual says "remove the PS pump". I did it once with the pump in place, and damaged a wire. I took the pump off, and while it was a bit annoying to pull the pump, it made the wire R&R a breeze.
really?? i got mine in place w/o removing the ps pump
Old Nov 9, 2009 | 05:55 PM
leadfoot4's Avatar
As I said, it can be done, but it sure isn't easy....
