How did you fix it ?
Old Nov 10, 2009 | 10:20 AM
djjab57's Avatar
Question How did you fix it ?
The bulb in my shifter is out and the dealership said you have to buy the whole piece to get the light, Thats ok i say now where do i go ? Radio Shack ? Thanks for any help here
Old Nov 10, 2009 | 01:18 PM
fleetmgr's Avatar
Radio Shack may have it, or may not. If not, try here http://www.mouser.com/
Old Nov 10, 2009 | 01:39 PM
SPEED#1's Avatar
I found one at auto zone.
Old Nov 10, 2009 | 01:54 PM
S2K's Avatar
S2K
From: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
I'm pretty sure I got one at advance.
Old Nov 10, 2009 | 01:57 PM
djjab57's Avatar
I bought one from auto zone and it wasnt even close, gm said since it is an LED light it was supposed to last forever. You cant even disconnect it you have to cut it off
Old Nov 10, 2009 | 02:12 PM
S2K's Avatar
S2K
Just to clarify you are talking about the one that lights up the "P R N D etc..." right? If you are I'm pretty sure it's the same bulb that is used in the door panels, to illuminate the switches. It was a little tough to get out when I replaced it. It ended up busting and I had to pull it out with some pliers.
Fyi, I went out in the rain and pulled the cover and checked just now. Things look exactly as I explained.
Old Nov 10, 2009 | 02:19 PM
djjab57's Avatar
Yes a real tiny LED bulb, i pulled and pulled. I guess ill just crush it if i have to
Old Nov 10, 2009 | 02:28 PM
S2K's Avatar
S2K
That's the one they show to go there
http://shop.advanceautoparts.com/web...S_201205481___
,but I actually have the PN# 74 in there. Same as in the doors.
http://shop.advanceautoparts.com/web...S_924520608___
Old Nov 10, 2009 | 02:38 PM
djjab57's Avatar
Autozone book said 194ll but that was way to big, ill go by advanced tonight and look at those and thanks
Old Nov 10, 2009 | 02:55 PM
S2K's Avatar
S2K
No problem, good luck.
