396 LT1 dyno numbers
Old Nov 18, 2009 | 11:57 AM
Formula934's Avatar
Default 396 LT1 dyno numbers
Specs:
396ci
AFR210 race ready 55cc
58 mm holly TB
3" dual X-pipe w/ flowmaster mufflers
LT4 intake
Hydrolic roller
477RWHP
433TRQ
93 octane
What do you guys think?
Going back in the spring to dyno with dual cut-outs and more tuning.
Old Nov 18, 2009 | 12:01 PM
AChotrod's Avatar
Nice work man!! Car should fly!!!!!!!
airfix's Avatar
Nice numbers man. the graph looks good to. Can you post up more info on your build?
Old Nov 18, 2009 | 12:39 PM
duh's Avatar
duh
Street build or Race? I'm diggin the TQ curve. Nice n flat and over 400 ft.lbs from 3500 to well over 6K!!! That thing should move pretty well, and keep pullin. That would be a phenomenal street motor, and probably live forever. I say spray it at the track and be happy! Nice build.
Old Nov 18, 2009 | 12:49 PM
DroppedM6Z's Avatar
Very nice curves
Old Nov 18, 2009 | 12:50 PM
zlicious94's Avatar
Gonna be a screamer!!
Old Nov 18, 2009 | 03:11 PM
FASTFATBOY's Avatar
Makes good power but torque is a little short.
Should be a ditch hunter.
Old Nov 18, 2009 | 04:55 PM
Robs94z's Avatar
Very nice!!
Old Nov 18, 2009 | 05:00 PM
Puck's Avatar
477rwhp from out of the box AFRs and an HR cam? I'd say thats nice .
Old Nov 18, 2009 | 05:10 PM
bowtienut's Avatar
Great numbers, especially considering thru the mufflers!
And with that torque curve, you have an EASY 10 second ride as long as the car has the other fundamentals.
Old Nov 18, 2009 | 05:50 PM
97Z28SS's Avatar
Excellent numbers is that thru an a4 or m6?
Old Nov 18, 2009 | 06:33 PM
BADHAWK51's Avatar
Nice numbers man.
Old Nov 18, 2009 | 07:57 PM
bowtienut's Avatar
Looks like an M6.
Glad you asked, cause I missed that earlier. Maybe 10's are a bit optimisic
Old Nov 18, 2009 | 08:53 PM
SPEED#1's Avatar
That is one sick *** setup u have there man, that car should fly.
Old Nov 18, 2009 | 09:03 PM
raymond mckinney's Avatar
How big is the cam?
Old Nov 19, 2009 | 12:13 AM
yonerhottlt1's Avatar
DAMN!!! Nice numbers!!
Old Nov 19, 2009 | 04:17 AM
Wicked94Z's Avatar
you're down about 50 ft lbs at 3000 rpm compared to my 388, not that it really matters you're making 450rwhp at 5500 on up. Throw some 4.56s in that thing
Old Nov 19, 2009 | 04:11 PM
Formula934's Avatar
Thanks guys for all the feed back.
It is a M6 for those wondering.
Additional specs:
Fidanza alum. flywheel 13 pounds
Stock rear end w/ 4.10
cam specs:
.610, .619 with the 1.6s but since the valves were hitting piston the 1.5s are on there. So im not sure of the duration and lift now. I need to whip out the cam card.
Static Compression is 13.1
I need to get back to the dyno and work out the timing. I logged the last run of the day and realized I was getting knock retard. i had upped the timing from the previous dyno visit and forgot to dial it back. Currently timing sits at 36,35 @ 95,100 MAP from 4-6500 rpm. Its pulling about 2-4 degrees of timing at each rpm interval although my knock counts are not increasing. So basically, the pcm's command to pull timing is actually more than the amount of factory base timing put in it. So, I think theres more power and torque to be made once that is corrected.
Old Nov 19, 2009 | 05:32 PM
duh's Avatar
duh
You're walking the fine line with 13.1 compression and 93 octane. I think it's awesome, but you will probably be fighting with the timing to get the thing to stay out of knock retard. Once that's figured out it should be killer!! Nice build.
Old Nov 19, 2009 | 06:13 PM
bowtienut's Avatar
I agree. Might as well pop some big injectors in there and retune it to run on E85 !
