my setup
Old 11-18-2009 | 09:48 PM
allenwesley's Avatar
Default my setup
hi yall i had a question about my setup... i recently lower my gear ratio in my rear to 323 (stock) for better street ability because i also putt in a th350 so i had to compensate for the lack off overdrive... now i also have a 3400 stall... i was curious what yall think a safe cruising rpm is for lt1? ive been cruising it at 2400 and was wondering if i could go higher? and was also curious if my cruising speed is at 55 at 2400 well i thought i would be able to cruze a little faster than that but could my rpm's be a little high because my converter is not locking up while im cruising? thank you for any help in advance
Old 11-18-2009 | 10:51 PM
duh's Avatar
duh
you went to the 4.10 from the 3.23? That would explain the RPM being at 2500 at 55 mph. You've got a strictly drag set-up. There isn't much for street ability there, not daily driver anyway. If you had a 3.73 it would drop that cruising RPM a little, but it still isn't going to be what a 4 speed would be. just drive it on weekends and at the track and you won't be hurting too much.....
Old 11-19-2009 | 07:31 AM
No I'm sorry I whent from 410 to 323... When I had the 410's and I was cruzing at 2400 rpm and let off the gas it would stay ther then slowly drop... But now with the setup I told yall about above I will be cruising at 2400 rpm's and when I let off the gas it will drop 400 rpm's then slowly go down from their so I was thinking it was somthing with my converter... Sorry for the spelling I'm on my cell phone trying to update this lol thanks for the help
Old 11-19-2009 | 08:34 AM
SS RRR's Avatar
Village Troll
Looks like you are sacrificing performance for comfort. There is always a fine line between those two items. If anything you probably should've gone with a 3.42 instead of a 3.23.
You can run your engine to whatever speed you want. It's just a simple fact that the higher the engine is revved for a given amount of time the faster parts are going to wear.
Old 11-19-2009 | 07:51 PM
thanks and yea i did lol and i was going to go with 342 but i desited not to at the last moment
Quick Reply: my setup
