Engine vibration. Not driveline related. Responds to RPM's.
My number 2 on the pass side has been burnt 4 times even if i tie wrap the **** out of it. I am putting OTVC MSD wires on next couple of weeks when the old motor comes out and new 355 goes in
Hey:
I, As well as you , hope the balancer is it, and thats the fix, sounds similar to what mine did, but mine was at higher RPMs then started to go to a wider range, 5500 6000, then 5000-6300 and then I fixed it. It was more of a deep buzz, I could feel it in the steering wheel when driving, real bothersome and annoying. I replaced it with a new SFI unit. it was then real smooth again. No problems since. The old one was loose enough to spin on it self.
Dub
When In Doubt Do Without
Dub
Update:
I am going to stop one tick shy of calling it fixed.
I installed the stock balancer. No change.
I then installed a new set of NGK TR6's (OMG I fuggin hate putting LT1 plugs in) and did not feel the vibe when free revving it in the garage.![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
I then drove it and humped on it pretty good and the vibe is no where near the intensity of what it was before. Before the change in the ash tray jingled pretty good and of course you could really feel it.
Now the change jingling is not near as intense and the vibe is far less intense as well.![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Plus the car feels even more powerful especially up top.![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
And it idles smoother too.![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
I think there is a very good chance the #2 spark plug boot was loose and that was the heart of the problem. The plugs all looked excellent and were consistent one to another in terms of burn pattern.
I will drive it some more tomorrow to ensure its good to go. What remaining minor vibes I feel are what I would consider very normal for a h/c loud exhaust 400HP motor.
Thanks guys for the help.
