396 build
Old Nov 22, 2009 | 08:35 PM
86formula's Avatar
Default 396 build
Ill be having a 396 LT1 built when i go to Iraq in 2 months. it will be nitrous fed (up to a 300 shot) and im worried about block strength. what are guys like Tanner and Tony Shepard (not meaning to leave anyone out but those are the first 2 that came to mind) using to ensure that this wont be an issue?
Old Nov 22, 2009 | 08:42 PM
96lt1m6's Avatar
PM Taner if he has time he will give you the run down
Old Nov 23, 2009 | 06:52 AM
86formula's Avatar
Anyone else? Maybe crank/rod/piston suggestions?
Old Nov 23, 2009 | 07:39 AM
Wicked94Z's Avatar
cola or callies crank, my recommendation is just to stay away from the chinese ****. Iraq is the perfect way to build a badass motor, I did it!
Old Nov 23, 2009 | 07:41 AM
moehorsepower's Avatar
Default Strength
Block fill...
Old Nov 23, 2009 | 08:24 AM
Tony Shepherd's Avatar
Half filled stock block, magnafluxed, sonic checked, 4 bolt billet main splayed with billet front cap and rear strap. I run a Cola forged 3.875 crank with Lunati billet 5.85' rods, JE custom nitrous pistons.
Old Nov 23, 2009 | 10:33 AM
86formula's Avatar
Thanks guys, any opinions on afr 227s vs trick flow 21* heads?
Old Nov 23, 2009 | 10:41 AM
86formula's Avatar
Before I get asked the goals are 10.5x on motor and 9.5x on spray. I'll be going with a fast xfi setup so I can spin higher then 7k if needed and switch between tunes for n/a and spray. I'll have a single plane on it with an elbow as well. Heads and intake will be potted by ai or le
Old Nov 23, 2009 | 10:54 AM
slomarao's Avatar
There is a thread about the TFS 21 heads and no one has really posted results. I would search for it.
Old Nov 23, 2009 | 01:31 PM
J2Pharren1's Avatar
SBC2.2 heads do it.
Old Nov 23, 2009 | 01:59 PM
waltsfastz's Avatar
Im working on a similar setup. I poured roughly 2 inches of Hard block in the bottom and Oliver 4bolt splay caps with studs. im gonna try the chinees **** in mine, Eagle 4340 Crank and H beam rods. going with Probe pistions with JE nitrous rings. LT1 TEA ported heads and a SR cam.
Old Nov 23, 2009 | 02:58 PM
86formula's Avatar
Originally Posted by Jperran
SBC2.2 heads do it.
not trying to spend that kind of coin lol. i thought about some converted 18* heads though
Old Nov 23, 2009 | 03:39 PM
Wicked94Z's Avatar
run the dart t4p heads that roadtrip is running from bret bauer
Old Nov 23, 2009 | 04:02 PM
86formula's Avatar
not really looking for something just being developed, id rather have something with proven results from more than one person.
Old Nov 23, 2009 | 04:16 PM
AChotrod's Avatar
Should be a sweet build!!!
Old Nov 23, 2009 | 10:28 PM
86formula's Avatar
anyone know if AI or LE have done a set of TFS 21* heads yet?
Old Nov 23, 2009 | 10:45 PM
gregrob's Avatar
Travis M. is having a set done. His build isn't finished yet tho
