Lt1 header installation problems
Old Nov 25, 2009 | 04:45 PM
schester97's Avatar
Default Lt1 header installation problems
I just purchased pacesetter longtubes and ran into some problems. Once I started to loosen the exhaust manifold bolts I had some that started to turn really slow and seemed like they could break. Any suggestions on how to get the bolts out. Or should I just not put the headers on. I have talked to a local shop and they recommend not doing the headers anymore. Please help.
Old Nov 25, 2009 | 05:39 PM
1993 z28 f1's Avatar
Hey:
PB Blaster let it soak overnite, then apply again 1 hr before you start,, that should get you started reapply PB Blaster as needed do not try to remove unless the blaster is seeped in good. Good Luck
Dub
When In Doubt Do Without
Old Nov 25, 2009 | 05:48 PM
schester97's Avatar
They soaked overnight and then I soaked them right before I tried again, no luck again. I am just worried about breaking a bolt, since there is no room to tap the bolt out.
Old Nov 25, 2009 | 06:01 PM
Z28_LT1's Avatar
Itll be alright. mine were pretty snug too. I think you should go for it. If you break one then maybe u should stop lol.
Old Nov 25, 2009 | 06:30 PM
schester97's Avatar
It's not that the bolts are tight, it's how they turn when i first get them to break free. It feels like they are about to break.
Old Nov 25, 2009 | 06:51 PM
94LTZ's Avatar
If you don't have the money to pull the heads if one breaks than leave them alone.
Old Nov 25, 2009 | 06:54 PM
schester97's Avatar
I just don't have the time to pull the heads right now if that were to happen. I guess I should just leave them alone for now.
Old Nov 25, 2009 | 07:39 PM
creepingdeath94's Avatar
Just soak them again overnight...run the car and get some heat, and then shoot em again with PB. Just go slow and be careful and see how it feels. Rotate around to other bolts or wait a bit in between trying to let it "cool" if it is getting hot/turning hard to try and avoid breaking it. You should be able to get a feel for it after a turn or two on the bolt if it going to break or not.
Old Nov 25, 2009 | 08:44 PM
fleetmgr's Avatar
Try working them back and forth (tighten a bit, loosen a bit) with LOTS of PB.
Old Nov 25, 2009 | 09:06 PM
schester97's Avatar
I did the pb blaster two different nights and tried tighten and loosen. I just got that bad feeling when the bolts starts to twist. I will just wait until I replace the heads and cam. Thanks for all the advice.
Old Nov 25, 2009 | 09:18 PM
integraxtc's Avatar
damn that sucks dude.
How long till you can do the heads/cam?
Old Nov 25, 2009 | 10:06 PM
schester97's Avatar
I went ahead and put on a magnaflow catback in the meantime, but it still sucks. Hopefully I can get the head and cam done this coming spring.
