burning oil after cam install
before my cam install, the car wouldnt burn a drop. now it will shoot a decent amount of blue smoke out when i go WOT. its not enough for me to see but my friends that drive behind me have told me they can see it. is this normal?
umm yeah, having to RTV the valve seals is the problem
. Did you lightly tap them into place with a socket and a rubber mallet? if not thats why there coming loose or popping off. you need to NOT RTV them. jeesh Trending Topics
I guess you have some valve springs to remove
The intake bolts dont call for any sealant either, just the gasket...
Your RTV'd valve stem seals are the issue IMO.
Im 99% sure stock heads dont need any sealant on the rocker studs. Lloyd made sure I knew wich ones would need them when I got my heads back from him, by putting black Xs on the stud holes that go into the runners
