Running put exhaust is popping
Old Nov 26, 2009 | 09:35 PM
96Formula6spd's Avatar
Default Running put exhaust is popping
Well we made some improvement on the car after 3 months of dead ends. Ending up changing my ICM and found a plug wire that was crossed. So it fired right up after cleaning the plugs. However when its running and you put a light load on the engine you start to get a loud popping in the exhaust. However if you give it a lot of gas it does not pop at all. The engine has not yet been broke in and that could be the issue. Also the car is still throwing a p1351 for the ICM voltage being to high. What do you guys think?
Old Nov 26, 2009 | 10:09 PM
red-_-z28's Avatar
how old is the gas?
Old Nov 26, 2009 | 10:27 PM
9 months old. Car has been sitting for repairs for a long time. Happy to see it running again for once.
Old Nov 27, 2009 | 08:08 PM
YodiBrodi's Avatar
the fuel could very likely be the cause. if its not a full tank dilute the mixture with fresh fuel. that nasty crap will cause it to misfire and run rough, get horrible mileage, and poor power. dealt with it before.
Old Jan 14, 2010 | 03:11 AM
1eyedmaro's Avatar
you ever find out the problem?
