Air foil.. Useless correct?
Old Nov 27, 2009 | 09:23 AM
custm2500's Avatar
Ph.D. in HUBRIS
Default Air foil.. Useless correct?
I have seen dyno results with no gains on TV but I just wanted to make sure you guys agree that it is worthless.
Old Nov 27, 2009 | 09:31 AM
86formula's Avatar
creates less turbulence in the airflow. its a cheap mod that may give you .01
Old Nov 27, 2009 | 09:55 AM
custm2500's Avatar
Ph.D. in HUBRIS
Like I said they show 0 HP on the dyno so like you said maybe .0001. I would rather use the 15 in fuel to get there!
Old Nov 27, 2009 | 10:29 AM
wrd1972's Avatar
No gains.
Old Nov 27, 2009 | 11:07 AM
hitmanws6's Avatar
the gain i have seen is 2rwhp/2rwtq. not my car.
http://www.ws6.com/mod-4.htm
Old Nov 27, 2009 | 12:11 PM
TheDon619's Avatar
i had one, it does smooth out the flow and give slightly better cfm, but not really worth it, i only had it bc it came on it when i bought it heh. my holly 58 has one built in so no need nemore
Old Nov 27, 2009 | 01:05 PM
Camaro350z2897's Avatar
doubt much gains of anything. I have one without a screw if ya want it.. wont cost ya 15 either.. more like 10 lol
Old Nov 27, 2009 | 01:17 PM
marc97taws6's Avatar
I have one but bought the car with it in there. Guy was claiming it makes the extra 10hp it claims too (As if I cared to listen, the car is going to be completely different when I'm done with it)
He claims to have felt a difference.. but people lie and dynos have proven its minimal effect.
Old Nov 27, 2009 | 03:23 PM
Rob's Avatar
Rob
It works. But a dyno is not where you'll see the gains. Take it to the track and run back to back runs with it. There will be a gain, small but a gain. It helps when the car is moving.
Old Nov 27, 2009 | 04:27 PM
djjab57's Avatar
With a car sitting on a dyno and no air being pushed in you wont see the gains. I have no idea how much you could really get from one but like said already it would have to be measured at the track
Old Nov 27, 2009 | 04:51 PM
bore.me's Avatar
$15 per horsepower isn't bad. Someone on here had some CFM ratings for it and and if i remember correctly the airfoil actually hurt airflow a little at low rpm but had a respectable increase at WOT.
Old Nov 27, 2009 | 05:00 PM
danhr's Avatar
the way i see it, all the big throttle body companies who put countless hours into r&d integrate air foils into their throttle bodies, so it has to atleast do something. if you find one for < $15, i would pick one up. people waste more money on dumber things, like a k&n air filter... so why not.
Old Nov 27, 2009 | 06:21 PM
94LTZ's Avatar
After running two of these i have noticed up top the car pulls smother. I ran one on my full bolt on, cam and P&P heads car and another on my buddies 383, 847cam, patriot heads and all the fun stuff and i could really tell on his car from a back to back run it was smother up top.
Old Nov 27, 2009 | 07:39 PM
Z-RATED94's Avatar
I think I once read they were worth like 20-30 cfm. Got rid of mine after having the stock TB ported to 52mm. Now I wish I would have kept it and modified it to work with the ported stocker.
Old Nov 28, 2009 | 05:10 PM
Elliott's94Z's Avatar
Every little thing adds up
Old Nov 28, 2009 | 06:56 PM
96lt1m6's Avatar
Well i had mine in for many years til i got a 52mm TB
DID not notice any ET difference at the track with it, i did notice my pocket was $30.00 less..........OK it did make the TB inlet look cleaner
Old Nov 28, 2009 | 08:06 PM
SS MPSTR's Avatar
This.
If you can get one cheap, it certainly won't slow the car down.
Old Nov 28, 2009 | 08:39 PM
James Montigny's Avatar
Mine came with a BBK 58mm, so I never got a chance to dyno with/without a foil.
I doubt there's much to gain, although if you can find a used one for sale cheap and still have a stock intake, go for it.
There's got to be a reason all of the aftermarket units have them built in.
Old Nov 29, 2009 | 09:54 AM
SS RRR's Avatar
Village Troll
That can be accredited to something as simple as engine/coolant temperature. There is really no way to document precise results like that with so many variables.
Old Nov 29, 2009 | 12:45 PM
AChotrod's Avatar
Agreed!
