Major Help! please
Old Nov 28, 2009 | 11:13 PM
94Z28'MachThis''s Avatar
Default Major Help! please
After having my car hooked up to DataMaster. I pulled a list of codes not just one or two... 58 different codes... Also at the time i did not think it was working so i did not drive the car around it was just sitting with the ebrake on, in neutral, only ran for 5 min top so the overheating codes i have no clue about.. here are the codes I threw.
11 MIL lamp fault
12 No DRP pulses
13 Left O2 fail
14 cool temp high
15 cool temp low
16 lo-Res fail
21 TPS
22 TPS low, high
23 MAT low
24 output speed low
25 MAT high
26 CCP electrical fault
27 EGR electrical Fault
29 EAS electrical Fault
32 EGR system faul
33 MAP high
34 MAP low
36 HI-Res fail
37 brake switch stuck on
38 brake switch stuck off
41 EST open
42 EST grounded
43 ESC fail
44 left O2 lean
45 left O2 Rich
46 fuel enable (VATS) fail
48 MAF system fail
50 System Voltage low
51 EPROM/Flash Checksum Fail
52 Oil Temp Low
53 System Voltage High
55 Fuel System Lean
61 A/C Low Charge
62 oil temp high
63 Right O2 fail
64 Right O2 lean
65 Right O2 Rich
66 A/C press sensor open/short
67 A/C press sensor degraded
68 A/C relay shorted
69 A/C clutch circuit open
71 A/C evap sensor failed
77 Fan fault 1 fail
78 Fan fault 2 fail
79 Trans over temp
80 Trans component slipping
81 Shift B solonioid fault
82 Shift A solonoid fault
83 TCC control feedback fault
84 3-2 down shift feedback fail
85 TCC stuck on
86 Low ratio
87 N/A
95 oil life lamp circuit fault
96 oil level lamp circuit fault
97 4000 PPM VSS circuit fault
98 Torque delivered circuit fault
99 tach output circuit fault
My car is not a peice of SH#% but with all these codes im starting to think other wise... The car is still running well just with a SES light on. Had it on the dyno 3 weeks ago and she put down 300hp and 330tq...
Old Nov 28, 2009 | 11:28 PM
RamAir95TA's Avatar
Only the codes in red are the actual codes, not in green.
Old Nov 28, 2009 | 11:42 PM
sooo i appologize for my nooooobness lol.... I was just going from the list it gave me of DTC code numbers 10-99 and the only ones that i could read what they where are what i listed... yes the ones in green lol... so what are the other codes that i could not read?.. also.. nothing was in red but i know my car is throwing codes.. Ill take it for a drive tomorrow and see what she pulls up again...
Old Nov 29, 2009 | 12:16 PM
RamAir95TA's Avatar
If nothing was in red then your car isn't setting any codes.
Old Nov 29, 2009 | 01:18 PM
JAKEJR's Avatar
Try disconnecting the battery to clear any stored code, then reconnect the battery and drive the car and see if any returns. Go from there.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
