y is my car overheating
Old Nov 30, 2009 | 07:57 AM
lil_lew52's Avatar
Exclamation y is my car overheating
i have a 93 z28 camaro that is overheating. all the hoses and waterpump is brand new. i have the right mixture nd water amount needed. thermostat is brand new as well(160 deg.) i bleed the valve so no air is in the system and my car still over heats. after i drive it and and shut it off i hear air bubbles movin around in the radiator. but wen the car is running i look underneath to see if any fluids are leaking and i see nothing. i just bought a new radiator cap last night and still having the same problems.
Old Nov 30, 2009 | 08:15 AM
ADM's Avatar
ADM
Are your fans even coming on?
Check the condition of your oil or coolant, check for cross contamination. If any, you need new head gaskets.
Old Nov 30, 2009 | 08:26 AM
lil_lew52's Avatar
yes my fans are coming on both of them. yes their looks like their sum water in the oil. but will that cause air pockets in my radiator
Old Nov 30, 2009 | 08:30 AM
old93camaro's Avatar
it may not be air pockets in te radiator but you have a crossover pipe in the rear of boths heads as well
