Thinking of a new build
Old Dec 1, 2009 | 07:20 PM
ADM's Avatar
ADM
Arrow Thinking of a new build
I just finished my build not long ago, and already itching to start wrenching again.
What I have in mind is a full forged rotating assembly 383ci, with AI ported 215cc TFS heads along with a custom cam to work with them, everything else I can transfer from my current engine.
I was thinking forged SRP pistons, but what rods and crank are best to go with?
What kind of hp figures am I looking at making?
Old Dec 1, 2009 | 07:24 PM
gregrob's Avatar
I would do a callies/compstar rotating assy.
RWHP is highly dependant on the transmission but that should be solid 10's N/A combo with all the other requisite parts and tuning.
Old Dec 2, 2009 | 08:21 AM
ADM's Avatar
ADM
I doubt a 4L60E (even rebuilt) would keep up with the way I drive my Z28.
I would love to carb the motor and get a TH350 or TH400 too.
I checked out SCAT kits on Summit at 1900 and include the flywheel and ARP rod bolts.
Any of the guys have experience with SCAT?
Old Dec 2, 2009 | 09:11 AM
Elliott's94Z's Avatar
AI all the way.. You will never look back!
+1 on the Callies/Compstar AI will get you squared away on the complete set up.
Old Dec 2, 2009 | 09:13 AM
ADM's Avatar
ADM
What cam do you have? And what did your car dyno and E.T.?
Old Dec 2, 2009 | 09:23 AM
It's a small streetable cam 227/231 .565/.601 108lsa
It's putting down roughly 407rwh through a built stalled A4. No track times yet. Come May I should have some after the track re-opens.
Old Dec 2, 2009 | 10:51 AM
slomarao's Avatar
Have you thought about just a cam swap?
Old Dec 2, 2009 | 11:16 AM
OutlawZ's Avatar
Callies/compstar is good ****...... Lunati makes a great crank.... hell you can do an eagle forged crank and eagle h-beam rods and it'd hold up forever.....
depending on cam selection i'd say you'd be looking at 425-430 RWHP easy with a T56 and probably 400-410 thru an auto.... if you go TH400 you'd lose more RWHP but the car would be a monster at the track and on the street....
Old Dec 2, 2009 | 11:41 AM
ADM's Avatar
ADM
I just finished my build about 3 weeks ago!
Self ported heads, CC503, 1.6 pro magnums, PS long tubes, 3 inch ORY, hooker aerochamber, milled heads, valve job, 918s and SLP cone filter.
Old Dec 2, 2009 | 11:43 AM
ADM's Avatar
ADM
I was hoping for more out of a 383ci with such great heads.
I was also considering going solid roller with AFR 227s and Jesel shaft rockers. More costly, but hell what a set up it would be!
Is SCAT not reliable enough?
