Need some help/suggestions
Old Dec 3, 2009 | 08:04 AM
Elliott's94Z's Avatar
Default Need some help/suggestions
Getting ready to replace my EWP and Opti along with some other small items. My questions are, I can't seem to find the OEM Opti from the Partsladi. Anyone have a link for it? Secondly, which valve cover gaskets are you guys having good luck with? I bought some Fel-Pros and they won't seal worth a damn. Lastly, are there any new latest and greatest spark plugs to go with?
Thanks for any help fellas
Elliott
Old Dec 3, 2009 | 09:11 AM
ADM's Avatar
ADM
You have to seat them correctly, there is a grove which is supposed to seat on the valvetrain walls of the heads (at least the ones I have do). They can slip out of place when you try to turn the valve covers over to seat them.
Try a very light dab of RTV on the valve cover itself to hold them in place perhaps? I did that and they sealed perfectly.
Old Dec 3, 2009 | 09:23 AM
I have positioned them a few different times and used RTV..still seems to leak on the passenger side.
Old Dec 3, 2009 | 10:01 AM
ADM's Avatar
ADM
Could your valve cover be slightly bent? Check that out bro. Fel-pro usually make great seals and gaskets, but there are always one or 2 that go bad.
Old Dec 3, 2009 | 10:34 AM
AChotrod's Avatar
I run autolite 104 plugs
Oriellys has some nice VC gaskets that stick/seal like a ****, litteraly I had to pry them off after 100 miles or so. Or just get GM Gaskets. I clean the VC, gasket and lip of the head with acetone b4 installing them. Never have a problem with them leaking.
I bought my Opti from Larry @ Speedinc. Dont remember how much it was but Im sure he will hook you up.
This is all I see at the partsladi store
http://stores.ebay.com/Thepartsladi_...&submit=Search
Old Dec 3, 2009 | 11:10 AM
Covers are straight..
Awesome thanks man! I will contact Larry for one.
Old Dec 3, 2009 | 11:17 AM
psiconversion's Avatar
LS1Tech Sponsor
rtv may be the problem. I use some permatex hi-tack on the gaskets so they dont move then since em down.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
