lowering springs
Old Dec 3, 2009 | 07:20 PM
9D4Z28's Avatar
Question lowering springs
im want to lower my car. i have no idea about what brands are good ? how many inches shoud i drop from stock height ?
Old Dec 3, 2009 | 07:59 PM
Elliott's94Z's Avatar
I really like the look of my Eibach Pro-Kit. I believe it lowered it just over an inch. Has a good stance and not too low if you want to run a TrueDuel set up. The Strano springs are another awesome choice which lower it a bit more. Go with some good quality shocks to top it off.
Old Dec 4, 2009 | 07:20 AM
97pontta's Avatar
I'm running Strano spirngs with Koni 4/4 shocks, couldn't be happier with the setup. Mine dropped about 1.2 inches from stock. IMO if your car is a daily driver you don't want to go much lower than 1.5 inches from stock or you will be on the bump stops a lot, depending on how nice the roads are than you drive on. Also keep in mind that there are a lot of different springs on the market with different spring rates and ride height. Matching the springs to the shocks is also very important to ride quality and handling of the setup. If you do a search in the suspension sectoin you will find hunderds of post to help you as well.
Here is a pic of my ride height, keep in mind my rear is about 3/4 of an inch higher than normal due to the Moser 9inch rear.
Old Dec 4, 2009 | 10:34 AM
slomarao's Avatar
Call sam Strano at strano performance parts. He will explain everything you could possibly want to know.
Im on strano springs and koni 4/4's also. Couldnt be happier.
I would get on the list for the next re order for the strano's. He cant even keep them in stock.
Old Dec 4, 2009 | 10:50 AM
rat93's Avatar
funny, my z is lowered and i hate it, but everyone else seems to dig the aggressive look... to each his own
Old Dec 4, 2009 | 06:24 PM
DroppedM6Z's Avatar
SUSPENSION TECHNOLOGIES 2" SRPING AND HAL'S QA1'S
You do have to learn to drive a car with a pro kit or most 2" springs or you will f up some LT's and some paint.
Old Dec 4, 2009 | 09:56 PM
94Z28rag's Avatar
That car is SEXY.
I loved my Pro-Kit.
Old Dec 4, 2009 | 10:10 PM
1 Craz28's Avatar
I opted for the Sportline. It sits just a hair lower. With KYB gas-adjust-shocks, doesn't rub a bit even with 285-40-17's on the rear. You just have to watch the nose and the cat if you go over speedbumps or park off-pavement.
It's handles ALOT better. Almost as noticable as going from 16in to 17in rims....
