Please help solve a Missing Problem
Old Dec 3, 2009 | 09:03 PM
Ru2slo_99's Avatar
Default Please help solve a Missing Problem
I have a 1994 Z28. I have had opti problems before and this is different. My car runs fine when it is cold, but once it warms up it misses bad. I thought it might be plugs and wires and replaced them with no positive results. I changed the coil and ICM. I heard that sometimes when the ICM heats up the car will miss. This did nothing. Freescan shows no codes, its running lean, 12 volts, and everything else looks normal I think. I thought maybe the fuel pump was not supplying enough fuel. I drove around all of today with a fuel pressure gauge. The pressure was around 32 at idle and 43 at WOT. I thought unplugging the MAF would make the computer stay in open loop mode incase the O2 sensors were screwed up. But it still misses bad once it warms up. I NEED HELP!
Any ideas?
Old Dec 3, 2009 | 09:38 PM
andysc's Avatar
Fuel pressure at idle should be 40 and 45 at WOT I believe, so you either have a restriction, clogged fuel filter, or bad pump.
hth
andy schuck
Old Dec 3, 2009 | 09:54 PM
86formula's Avatar
i had that problem and it was my O2s when was the last time they were changed?
Old Dec 3, 2009 | 10:05 PM
Smoke Em's Avatar
^^ check o2s
Old Dec 3, 2009 | 10:26 PM
Ru2slo_99's Avatar
I will change the fuel filter this weekend.
I changed the O2 sensors a little over a year ago because of a failure. If the filter does not do anything, I will try new O2s.
I set the FPR at 42psi so the WOT pressure is what it was. If it was a fuel problem why would it run fine before it warmed up?
Old Dec 3, 2009 | 10:41 PM
Smoke Em's Avatar
when you floor it does it hesitate bad and skip, and barely move like it should?
Old Dec 4, 2009 | 11:25 AM
Ru2slo_99's Avatar
Yes! It snaps and snarls and pops at any throttle position. Anywhere from cruising to WOT.
Old Dec 4, 2009 | 11:32 AM
rat93's Avatar
o2s, they dont do anything on cold start
Old Dec 4, 2009 | 11:38 AM
pillarpod's Avatar
vacuum problem?
Old Dec 4, 2009 | 03:31 PM
Ru2slo_99's Avatar
I have sprayed WD-40 all over the engine while it was running with no stumbles. How do I find a vacuum leak?
