turbo lt1
Old Dec 5, 2009 | 11:54 AM
cgperformance1320's Avatar
Default turbo lt1
what how much boost will my stock lt1 handle?
thinking about twin t3/t4's
also any suggestion as far as a cam that work well with this set up ?
thanks
Old Dec 5, 2009 | 11:56 AM
kinglt-1's Avatar
8lbs with a spot on tune.
Old Dec 5, 2009 | 12:04 PM
WARDOG's Avatar
Default single
I would suggest goin with a singel turbo setup.Twins means 2x everyting from oil lines to piping etc and there aint much space around an lt1. Power master turbos make a 70mm for about 585 shipped. And 8psi with supporting mods would make about 450rwhp +/- a couple of ponys . Good luck
Old Dec 5, 2009 | 12:10 PM
i have a set of headers with t3/4 flanges on them thats the only reason i was thinking twins but i think you maybe right a single set up would be alot easier thanks
Old Dec 5, 2009 | 01:33 PM
kinglt-1's Avatar
I agree a single turbo would be better. The lt1 has plenty down low, needs more up top, wich is what a big single will give it!
Old Dec 5, 2009 | 02:17 PM
96capricemgr's Avatar
Tear it down and open the ringgap some.
