timing set to use with 24x?
LT4 extreme duty, thats what i went with. It aint cheap though..
RamAir95 - 24x is the LS1 pcm conversion:
http://www.eficonnection.com/24x/default.htm
new front cover pictured here and the route I will be going
A new heavy duty single row timing set (if running electric pump) is about $80.00 from Summit.
Keep in mind this is billet and begins as a 20lb piece of material. Then machine time and so on. No one can make a billet timing cover for less than the price of a heavy duty single row timing set. Unfortunately not even close.
PS: When will the cover be available for purchase.
(At this time) all of the timing covers will have crank sensor provision. But we have plenty of sensor plugs lying around that bolt in the sensor hole and seal with an O-ring.
The covers will be available for purchase in the upcoming weeks. The first batch of these covers will begin this week.
