93 firebird lt1
Old Dec 6, 2009 | 09:27 PM
jonesracing's Avatar
Default 93 firebird lt1
Iguess 93s didnt have mass air is that going to efect me installing a bigger cam or other perf mods, and is there a programer out there that lets me make changes like timing and fuel in the ecm or do i have to get burnt chips,im all new to this ecm stuff ,if its gonna be a hassle im going carb.
Old Dec 6, 2009 | 09:30 PM
whytryz28's Avatar
You would need to get a chip if you want to tune it, PCM4Less of Ion does this for 93' cars.
Old Dec 6, 2009 | 09:37 PM
James Montigny's Avatar
Correct, 93s do not have MAFs.
They also have ECMs that take a little longer to process data and compensate.
Yes, they do require rewritable chips be burned and installed. Although it's a simple process.
The ECM itself doesn't really become an issue with most cam choices.
Although I had problems getting something with a lot of overlap working properly.
Make sure you get a good tune to match your setup.
I recommend FastChip.com, Ed's arguably the best LT1 tuner you'll find.
You can tune it yourself if you have the software and a chip burner.
I've had it done that way too, worked ok to get the car running and driveable with the ported heads and 224/230 cam,
but a good dyno tune at Ed's made a world of difference.
You could convert to carb if you really wanted to.
It would make tuning a little easier, but you won't get the performance or economy you would from an EFI setup.
