Hurt the LT1: Video inside
Old Dec 6, 2009 | 10:45 PM
Matts94Z28's Avatar
Default Hurt the LT1: Video inside
Took the car to the track tonight and hurt it. On my second pass it did not shift into second and hit 7k or so RPM. I ended up going 7.92@82 mph... the car usually traps 88-89mph.
Anyhow, there was alot of chatter under the passanger valve cover so I figured I broke a 918, rocker or pulled a stud. Well i got the cover off to find everything okay! I just cant figure out what the noise is... I am wondering if I could have floated a valve and possibly had some contact. The car runs fine, it does not skip or miss... I just have this strang noise.
Any thoughts on what it might be?? The car has a cc306 (230/244 .544/.576) Comp roller tips (1.6) and SRP 11:1 flat tops with -5cc reliefs. Seems like I would have a ton of room, even with the impala gaskets. I hope it's not a bearing... I know it doesnt sound like it, but who knows at this point. I need to hook my pressure gauge and verify the psi. Although it is gettin oil up top just fine.
I also only ran 5qts vs running an extra qt to prevent starvation upon launch, but I only cut a 1.81 60' so I doubt that was an issue.
http://www.youtube.com/watch?v=uuLkhZVQacs
Old Dec 6, 2009 | 10:48 PM
James Montigny's Avatar
Did you drain the oil and check for metal bits?
Old Dec 6, 2009 | 10:51 PM
Matts94Z28's Avatar
Not yet, I pulled the dip stick and didn't see anything on it though. It sounds like it's coming from the rear cylinder... doesn't sound like a bearing at all, but you never know. The bottom end is fresh still... it has maybe 5k miles on it at most. New clevites, turned crank and all arp hardware.
Old Dec 6, 2009 | 10:57 PM
I hope you're right, I'd just want to be sure before I ran the motor a whole lot.
If something's wearing, you'll find it in the oil and/or filter.
Might be able to save something or at least gain some peace of mind.
Certainly does sound noisier than it should be.
But if the springs are not broken, pushrods look strait and the engine is running
well, it's tough to tell what might be causing it without a leak-down test or a scope.
Old Dec 6, 2009 | 11:01 PM
Matts94Z28's Avatar
Yeeaaah... I am HOPING it's not the bottom end, because I will not be going back with an LT1... thats for sure. I have built two of them and I am just about tired of it. I have been DDing the car since june without any issue and now this. Granted it wouldn't cost much to replace the bearings and have the crank cut/polished, I just don't feel like pulling the motor for a third time.
Old Dec 6, 2009 | 11:30 PM
LT1's Avatar
LT1
Sounds like its valvetrain noise.
Old Dec 6, 2009 | 11:33 PM
riceburnerZ28's Avatar
Sounds like it's coming from the valvetrain. Do a compression check and definately keep a eye on the oil. Get a stethoscope or a screwdriver and put it on each rocker and listen for any odd sound.
Old Dec 6, 2009 | 11:43 PM
speedracer2536's Avatar
dude on a side note.. my stock lt1 when i had the vc off when idid the cc306 had a ton of oil pressure and it would spray pretty good with the vc off.. do you have low oil pressure?
Old Dec 6, 2009 | 11:52 PM
Matts94Z28's Avatar
I have not verified the oil PSI... the stock gauge is broke, but I have the sender for the autometer installed, just need to wire it up tomorrow and check.
Old Dec 6, 2009 | 11:54 PM
ya when i started it up i pretty much ran it for less than 5 sec. it sprayed out of the car lol..
Old Dec 7, 2009 | 12:02 AM
Matts94Z28's Avatar
its getting oil up top, you can see it spray on the cardboard... which is why I put it there. I assume the oil PSI is fine, but anything is possible at this point.
I just cant figure it out because the springs are fine, the rockers dont seem to be broken, it doesnt sound like a lifter and the noise is only on one side.
Old Dec 7, 2009 | 12:04 AM
Matts94Z28's Avatar
Wonder if a plug could have backed out or maybe the header gasket blew out.
Old Dec 7, 2009 | 12:08 AM
kinglt-1's Avatar
bent pushrod?
Old Dec 7, 2009 | 12:09 AM
im gonna say maybe exhaust gasket.. it goes away seems like whn u give it gas..
Matts94Z28's Avatar
They are chromoly and all appear to be fine, this sure has me baffled. I just hope and pray it's not a bearing.
Old Dec 7, 2009 | 12:12 AM
SPEED#1's Avatar
Sounds like a header gasket to me ONLY>
Matts94Z28's Avatar
I have never heard a gasket sound that way, but I just went out and checked and the rear header bolt is gone and I noticed the trans case is touching the primary (new case when built). This could be making that noise... but I don't know why it would be an issue after making this pass... seems like it would have shown up before hand.
Old Dec 7, 2009 | 12:15 AM
marc97taws6's Avatar
Car is definitely pulling some good slips! Now get the motor fixed and keep it up!
Old Dec 7, 2009 | 12:24 AM
Matts94Z28's Avatar
Thanks! I appreciate it... lets just hope its something small... I am hoping its a header gasket... but it just doesnt add up as to why the noise would appear after the pass where it hung up around 7k for a second or so. I bumped into neutral right away. As I said, the car does not skip or anything. The only thing I dont know at this point is the oil psi.
Old Dec 7, 2009 | 12:31 AM
Matts94Z28's Avatar
Found a similar sound in another video on youtube... give me some hope
http://www.youtube.com/watch?v=tsWz4s4vrMM
