Hurt the LT1: Video inside
Old Dec 7, 2009 | 01:18 AM
kalebm22's Avatar
Restricted User
i noticed you have stamped steel rockers instead of full roller rockers. this could have something to do with why your car isnt building more power on the dyno(i read your other post). i think you could pick up some descent power up top and that might get rid of the vvalvetrain noise
Old Dec 7, 2009 | 07:34 AM
bowtienut's Avatar
What kind of valvesprings are you running? Check for bent rocker studs, bent pushrods. If no bent studs or pushrods, relash the valves to see if it helps.
I also can't rule out exhaust leak based just on the sound in the video.
Old Dec 7, 2009 | 09:12 AM
fergymoto's Avatar
It sounds more like metal on metal rubbing than a tick or tap to me. I would check all the rocker arms for a bad bearing, then lifters, and if you find nothing wrong by the time you're done with that you can look in the bottom.
Old Dec 7, 2009 | 09:15 AM
Matts94Z28's Avatar
It was just an exhuast leak... by far the strangest exhaust leak I have ever heard. I also readjusted the lash on the motor with it running (never done it that way) and the motor is dead silent now. Time to go out and run some 7.6x's this coming weekend.
BTW, I do plan on upgrading to better springs and full rollers once I do heads. I don't like the fact I have 15k on my 918's... they are probably about wore out.
Old Dec 7, 2009 | 09:25 AM
fergymoto's Avatar
That's some good news! Maybe the video just didn't pick up the sound good but I never heard an exhaust leak that sounded like that.
Old Dec 7, 2009 | 09:27 AM
Matts94Z28's Avatar
I haven't either... I was sure I had a broke valve spring or something. I am just happy to have it fixed so easily. Time to put the 200 pills in and see what it does.
Old Dec 7, 2009 | 11:07 AM
robsquikz28's Avatar
Sounded like a exhaust leak to me!!
P.s I just looked at the bottom after posting and it is,lol. Its better than having a engine problem.
Old Dec 7, 2009 | 12:03 PM
SPEED#1's Avatar
[QUOTE=Matts94Z28;12589814]It was just an exhuast leak... by far the strangest exhaust leak I have ever heard. I also readjusted the lash on the motor with it running (never done it that way) and the motor is dead silent now. Time to go out and run some 7.6x's this coming weekend.
As I thought it was, now go fix it!!!! LOL
Old Dec 7, 2009 | 12:07 PM
riceburnerZ28's Avatar
Glad you found the problem...that sure was a weird sound!
Old Dec 7, 2009 | 12:17 PM
AChotrod's Avatar
Sounded just like my last exhaust leak at the header flange.
Old Dec 7, 2009 | 12:42 PM
blackz93's Avatar
My exhaust leak sounds pretty much like this.
