has anyone done this?
Old Dec 8, 2009 | 09:18 AM
speedracer2536's Avatar
Default has anyone done this?
im looking at parts and i notice that the arp bolts for the 4 bolt main are only 32 dollars. where as the studs for the 2 bolt main are like 70 something couldnt i just but the bolts for the 4 bolt main and use them?
http://www.summitracing.com/parts/ARP-134-5202/
Old Dec 8, 2009 | 09:32 AM
answered my own question.. nvm. it was in the application part and you can
Old Dec 8, 2009 | 10:11 AM
myltwon's Avatar
probably the difference is the 4 bolt main one's don't come with windage tray studs
Old Dec 8, 2009 | 10:31 AM
do i need to run a windage tray? im planning on running the canton after a little bit.
Old Dec 8, 2009 | 10:54 AM
SS RRR's Avatar
Village Troll
The Canton 242T has a built in windage tray, however it is finicky with oil. There have been several reports from those who can't use the full 6qt. capacity w/out having windage problems. I use either 5 or 5.5 quarts with a large filter and am fine.
Don't run the engine unless it has a windage tray.
Old Dec 8, 2009 | 10:56 AM
im going too call arp or summitt and ask them then im curious as to how the lt1 corvette windage tray system is..
Old Dec 8, 2009 | 11:05 AM
SS RRR's Avatar
Village Troll
They won't know. There is no system per se. It's just a flat piece of steel that bolts onto the studs.
It's of poor design since there have been complaints of windage especially during hard acceleration, but it keeps windage at a minimum. Running w/out it could mean suicide to your bearings.
Old Dec 8, 2009 | 11:16 AM
so from all that im gathering the corvette lt1 uses the exact same thing.. maybe it does come with studs.. im going to call and find that out
