Going carb = no optispark
It drives fine when you first start it, then as it warms up or after 20 mins of driving it starts backfiring out the exhaust, sputtering, and missing like crazy. Especially under load.
I remember all these symptoms before replacing the previous one.
I am considering going carb just to get rid of the worst distributor to be ever made, unless I can get a coil pack system and keep the fuel injection part of it.
Rant over
I turned the car off, back on and I heard a pop as it fired up, but then funnily ran smooth? (crazy LT1s).
Fast forward to today, driving to the mall, all good (no rain today roads dry). Drives ok, get to the mall and then starts to sputter. Its usually doing it in idle in gear or when I'm just about to move and then clears out.
However, on my way back, it drove alright for a few mins and then it starts to sputter in gear, rpms dropping really low, had to throw it in neutral many times and rev it, and it would still drop and not idle. Then as I tried to get her moving on the road to get home it started to back fire and miss heavily.
I really hope its a few ignition cables burned by the headers or something and not the opti. I'm trying hard to save for a stall and don't want to be investing into another opti.
I would rather go carb!
I will scan for codes and get back to you guys. 5 mins.
When the wires were wet there were sparks shooting out of them like the 4th of July. Got new MSD wires and all the problems were gone.
Spray a mist on the wires and watch for sparks and crackling noises. If these effects happen, you need newer lower resistance plug wires.
This!! ^^^
I bet the % of improperly diagnosed opti failures is WAAAAAYYYYYYYY up there!
First thing I did, I reflashed my PCM back to the OEM tune. Believe it or not, no misfiring during driving and ran smooth except in traffic it drove like crap (as expected) but was really weak compared to tuned of course. I even logged the driving on FreeScan (will try to upload it).
Then I stop in a parking lot, and reflash the PCM to the tune I got. Car drove well for a few mins, and then it goes all hay wire. I was logging on DataMaster this time though. It was sputtering like crazy, sounded like it was running on half the cylinders :S even the O2 sensors were reading very far apart. One was 5xx mV and the other 1xxx mV :S
Almost home, I start hearing a ticking from the engine, sounded loud (engine still sputtering). I stopped at the parking lot and popped the hood (it was also struggling to idle), the sound was coming from within the engine, like it was a lifter stuck or something.
I will look for a site that I can use to upload the logs and if any of you guys could look it up.
I kept getting the EST OPEN code but I don't understand how I could get it when my opti is practically new. Knock counts even hit 60,000! WTF?
I am having a really bad day
EDIT: the roads are dry now and there is no rain.
Thanks
the opti may not be the most robust design, and its not in a great location, but it gets the job done and its not half as bad as people make it out to be.
The passenger side O2 is reading a constant 1097 mV from start up, which looks its not even reading as it seems, but the driver side is reading and fluctuating depending on amount of throttle.
EST OPEN code remains, and so does the tick that sounds like a stuck/collapsed lifter (coming from the intake area). Engine won't even idle, like most of the cylinders aren't even getting any spark.
Will check if all cylinders are getting spark.
I get to keep my fuel injection, will get 2 new O2 sensors and ready made extensions.
Only problem is it will take 3 weeks to get a harness done for my car (unless they have one in stock).
