need help relocating oil filter
is there an oil cooler above the filter i can remove to gain enough clearance to put a filter on until i get the kit? thanks
(You know ... right after the pump where all the pressure is)
happened to come loose or melts ... you're absolutely screwed.
Having soft hoses run next to headers where there was limited clearance to
begin with makes it that much more risky IMHO.
If the headers don't clear a standard (or even a shorty) oil filter, don't use the headers.
I'm sure 1000 people will reply telling me they're doing it and not having problems.
Great ... congrats. Don't come crying to me when you find out what happens to an unlubricated rotating assembly.
Hope all this helps.
