Injectors Question...
Old Dec 14, 2009 | 04:18 PM
scott937's Avatar
Default Injectors Question...
How do i test the injectors for how much pressure there putting out? And how much pressure should it be? Any help would be great thanks
Old Dec 14, 2009 | 07:16 PM
red-_-z28's Avatar
26lbs/hr
Old Dec 15, 2009 | 01:53 AM
RamAir95TA's Avatar
Originally Posted by red-_-z28
26lbs/hr
Uh, no.
Stock flow rate for for 94-97 LT1 injectors is 24#, while 93s use 22#.
I'm going to assume you're talking about rail fuel pressure. You need a fuel pressure test gauge that attaches to the Schrader valve at the back of the intake manifold.
Fuel pressure should be around 43psi with the key on, engine off, then drop slightly with the engine idling and gradually increase with throttle position.
Old Dec 15, 2009 | 12:40 PM
scott937's Avatar
Originally Posted by RamAir95TA
Uh, no.
Thanks im gonna check that out today
