Fastest LT1's on LS1Tech.com
Old 12-18-2009, 11:03 PM
gregrob's Avatar
Originally Posted by BOLO
On the N/A list,---Mike CompT/A #57 10.89@128--- Is that on N20 run? stock bottom end. I thought I saw that same time on another forum stating that run was on 150 shot? But, if thats an all motor pass on stock bottom end, hey thats one hell of a motor!!
Oh, thanks for the update.
Not sure, I'm just going on the info I have and what was on the old list, and theres no power adder stated??
Originally Posted by BADHAWK51
Ok looks like you took care of Brady now I just need to be moved up a few spots.
Jeff Stark(Badhawk51)-10.92@121.44, 94 Firehawk, 383, Brodix heads, FLT 4L60E, 4000 stall, 12 bolt 4.10 gears
Got er dun. Was editing via my phone earlier and it would let me delete Brady's slower run but wouldn't let me add you. All should be good now.
Keep it coming if you see corrections that need to be made guys.
Thanks
Old 12-23-2009, 10:11 AM
quik95lt1's Avatar
I need an update
OLD:
quik95lt1-11.40@121.5
NEW:
Mike V quik95lt1 - 10.707@128.4 w/1.56 60' 385ci, 13.9:1, AI TFS215cnc, AI SR Cam, 4000 Vigilante, 3515#
Thanks, I've been trying to get on here for ever with the new motor.
Old 12-26-2009, 12:30 AM
gregrob's Avatar
Gotcha up there Mike
Old 01-08-2010, 06:34 PM
93z28joel's Avatar
13.60 @ 101MPH 1993 z28 A4, stock with 175,000 Miles
Old 01-13-2010, 06:36 PM
1fast84's Avatar
Does that list include b bodys or just f body's? Mike harris should be on that list he has a 94 impala and runs 10.40's i believe and didn't see him on the list. He has an LT1 with no power adders
Old 01-17-2010, 09:19 AM
fuel's Avatar
(Fuel) 9.514 @ 139.27 (1.335), 94 Z28 , 383 LT1, AFR 210 comp port, 3400lbs,n2o
this is my new time..............
Old 01-17-2010, 08:41 PM
TravisMcGill2000's Avatar
94 ta full boltons beside ewp, 3.42 gear, 3800 stall.... 12.3@108 1.59 60ft na. 11.20@120 1.61 60ft 150 shot
Old 01-17-2010, 10:12 PM
roadtrip120's Avatar
Update on the N/A List
Brady Matysek (roadtrip120)-10.075@135.63 (1.48), 94 Z28 M6, 385 LT4, Dart CNC Pro 1, Solid roller, 3240 lbs, 1550ft DA N/A on E-85 "Fastest N/A 6spd"
Old 01-28-2010, 11:47 AM
OutlawZ's Avatar
Hey I just looked at my times are updated but i'm sitting in the wrong spot. I should be right behind Joey Kenville.... Me and Jeff Gilbert have the same ET but I have him by 2 MPH for the tiebreaker.....
Old 01-30-2010, 01:25 AM
gregrob's Avatar
Cool, fixed it.
Old 01-31-2010, 12:15 AM
gregrob's Avatar
Put it in this format for me:
Travis Spence (tspence45)-13.205@105.55, 94 Z28 M6, LS1 lid conversion, LT's, TD's, DR's, MadZ28 tune
Old 01-31-2010, 12:21 AM
  #32
Z28Camaro30Ann's Avatar
Cory Carpenter (Z28Camaro30Ann)-13.695@103.73, 97 SS M6, 355, full bolt-ons, AFR's, and more, N/A
Old 02-14-2010, 02:22 AM
  #33
LSxPwrDZ's Avatar
I'd like to add a buddy of mine that posts on here quite often...
Frank Staton (HVYSS) 11.19@118.9mph - 4300lb race weight, .040" over LT1, LE2 Heads, GM847, 4.10, 28x10.5, 4L60E, 3500 PTC, 150 shot
http://www.youtube.com/watch?v=nMmo4...layer_embedded
Old 02-17-2010, 10:14 AM
  #34
gregrob's Avatar
Updated.
Old 02-20-2010, 10:27 PM
  #35
cgperformance1320's Avatar
cgperformance1320 13.51@103 2.0 60'-96 z28 a4 m6 rear shorties true duals free mods n/a
Old 02-23-2010, 01:28 AM
  #36
c5formula's Avatar
i got one for my car.
c5formula-11.85@120 stock bottom end, le2 package, 3450lb, n/a
Old 02-26-2010, 11:43 AM
  #37
gregrob's Avatar
updated.
Old 03-07-2010, 12:24 PM
  #38
my power adder numbers
cgperformance1320 11.62@117.4 1.57 60'-96 z28 a4 m6 rear shorties true duals free mods 150 shot
Old 03-08-2010, 06:28 PM
  #39
gregrob's Avatar
What does "z28 a4 m6" mean. Which is it?
Old 03-09-2010, 03:03 PM
  #40
its a a4 but it has a m6 rear end
Quick Reply: Fastest LT1's on LS1Tech.com
