Fastest LT1's on LS1Tech.com
Old Dec 17, 2009 | 09:47 PM
gregrob's Avatar
Default Fastest LT1's on LS1Tech.com
Please add your times in the format of all the others you see below.
There are 2 main lists, POWER ADDER and NATURALLY ASPIRATED.
Add what kind of power adder at the end if your times for the PA list, and N/A for the NA list.
[+] THE POWER ADDER LIST:
  1. Tony Shepherd 7.38 @ 187.00 Turbo
  2. TyTech 8.039 @ 173.63 87 Camaro A3 383 AFR210 88mm
  3. Big Rick" Intrau-8.08@176, 96 T/A, Lots of stuff, single turbo
  4. Stefan D--8.43 @ 143---401 CI LT-1-AFR 215RR-SUPER VICTOR 18*- F-1 REVERSE
  5. Tony Shepherd 8.453 @ 163.58 1.25 60ft 5.43 @ 130.37 1/8 93 Z28 , 396 LT1, PG, AFR 235, Nitrous Outlet fogger, Current LT1 N2O record holder
  6. Carlos Saberbein 8.46@160 1.19 60ft 5.38 1/8@129, 385LTx, Glide, AFR 227, DP 31N jets
  7. Josh H. "Ponyhntr"-8.503@ 155.54, 96 Z28 A3, 383, AFR227, ProCharger F1A-94
  8. Madman & Omahar Berry-8.55@169.9 Firebird, 380ci LT1 with GTP AFR 215s twin turbo
  9. Mark D 8.69 @ 155 68 SS Camaro 396 LT1 150shot
  10. strokedz 8.71@160 1.30 60' Lt1 383 9.5 to 1, AI TFS heads, procharger F1A, AI sollid roller cam, AI accel converted single plane, glide, 5000 stall, moser 12 bolt 3.73 gears
  11. Taner-1.30 60', 8.81 @ 155.05 3500#, 96 SS 399ci Harshaw Racing Engine, Full BMR suspension. Quickest and Fastest M6 F body / First LT1 6spd f-Body in the 8's and 9's
  12. Bigcat7274 8.90 @ 153 383 WITH AFR 210'S AND A YSI VORTECH.
  13. Chris Sikora “Z8’s”-8.928 @152.61, 383 LT1, GM LT4 Heads/Intake, Vortech YSi
  14. jakesz28-8.957@151.60, 94 Z28, LME 383, 350 shot
  15. Joey Kenville 9.04@150, 97 camaro, th400, 396 speedtech plate, 3100lbs
  16. Jason Brisson(OutlawZ) 9.06@153.8, 1.35 60' 95 Z28 A3, CSM Race Engines 383 AFR 227's, SR cam, Single plane, TH400, 9", 3.89's, 3400 race weight, Nitrous Pro Flow PLATE
  17. Jeff Gilbert (SSANDTA)-9.06@151.48, 96 TA 398, D1, A3, LT1 intake, AI TFS LT1 heads , OBD1 PCM, 100 shot, 3562lbs
  18. Spray-9.08@159.7mph, 95 Z28 383 LT1, TH-400, N20
  19. Dave DiLuca "SLED28"-9.11@155, 396 LT1, AFR's, TNT Fogger, 3415lbs
  20. (KYLE KLINE)kline454-9.24@145.61 (1.34 60ft),5.88@117.88 1/8. 95 Camaro,A3,AFRs 210heads, 383 11.5cr,custom solid roller,carbed super victor,all bolt-ons,nitrous,3400#
  21. Mike Harvey(strokedz)-9.26@150, 95 camaro, Lt1 383 9.5 to 1, AI TFS heads, AI sollid roller cam, AI accel converted single plane, glide, 5000 stall, moser 12 bolt 3.73 gears
  22. Jason Warren-9.3@142, 95 Z/28, 355 LT1, TH-400, LT4 TrickFlows, LT4 intake, stock crank, stock pcm w/recalibration, solid roller, 300shot, 3578lbs.
  23. Jeremy McKinney (vtec/diggler)-9.44@139, stock shortblock LT1, ported factory heads, 3100#, nitrous
  24. 383racecar-9.45@140.61 (1.31 60ft),5.97@113.64 1/8. 95 Camaro,A3,le3 ported stock lt1 heads 383,custom solid roller,carbed super victor,all bolt-ons,nitrous,3400#
  25. Andrey Sokolov-9.48@144 94 Z28 A3 383, YSI, 190 AFR's, 9"
  26. (Fuel) 9.514 @ 139.27 (1.335), 94 Z28 , 383 LT1, AFR 210 comp port, 3400lbs,n2o
  27. Dallas Castro(Frst 9 prchrgd LT1)-9.53@148, 355 w/ D1 Prochager, 3540#
  28. Eric Rheault (Row)-9.56@140.82 385ci,AI200 heads and intake,th400,9", 250 shot, 3700#
  29. Johnny Clevenger (turbo383ws6)- 9.64@140.84 (6.15@112 1/8th), 96 Trans Am, TH350, 383ci, GT4788, full exhaust, stock block (no fill), stock mildly ported heads, A2W, 3850lbs
  30. Larry "LS1 SPEED" 1/4 et - PA - 9.67@138.9 mph 1.31 60ft. 396ci, HR, stock ported heads/intake, FLT 4L60E, 3.73, Yank SS3600, Nitrous Outlet 200 shot / 3380 #'s ( no bump )
  31. 383racecar-9.78@138.11 (1.39), 95 Camaro,A3,le2 383,custom solid roller,carbed super victor,all bolt-ons,nitrous,3500#
  32. Ray@nitrous outlet-9.826@132.02 (1.42), 94 Formula, 700r4, 396/200 shot,AFR 227s, 246/254 .613/.590 112lsa, 3600 stall, 3.73's 3220lbs
  33. TwoFast4Lv-9.82@137, 3L80 w/brake,A1 5,500 conveter, LE-X heads, Nitro Dave's MM 200HP N2O, LT1 3,550lbs, 12 Bolt. Fully Prepped at Speed Secrets!
  34. T/ALT1-9.83@136mph, 95 T/A, 355 LT1, 10.5.1, CC306, LE Trickflows, LT4 intake, stock injectors, 3800 PI converter, TH350, 8.8" rear, 3.55's, 175 shot, 3,450lbs
  35. Mike Acton (mdacton) 9.87 140 1.33 60'383, ported stock head, 750 carb th350 150 shot Nos plate
  36. Mike V. (engineermike)-9.92@146.0, 95 Z28 A3, T76GTS turbo/3750lbs
  37. hvyss--9.92 @ 134 1996 Impala SS 385 ci LT1 AI 200cc H/C/I, TH400 175 shot
  38. Pat Burton 9.96 @135.5 LT1 P600b AFR 210 383ci 4l80e 10 bolt 3620lbs
  39. LT1Tony (Tony Karamitsos) 1994 Camaro Z28, 396, 6 Speed, 200 Shot, 3,700#, Hydraulic Cam
    10.06 @131.5 with a 1.35 60ft. Best Mph 135
  40. Kyle Mckenzie (Formula383) 10.13 @ 136.07 w/1.45 60', 383ci, Solid Roller, AFR210's, LE Cam, M6, 250 shot, 3600#
  41. Mark (badazzz28) - 10.19@134.14 w/ 1.51 60' (6.55@107.30). LT1 383 forged 4bolt, AFR 195, NOS plate kit, comp cam, EFI-converted super victor, TH400 with ~2800 stall, 3.54 danaS60 spool, 30" MT radials, 10pt cage
  42. Z28&WS6-10.19@128.9, 94 Z28 383 T-400 D1SC 10-bolt 3.73
  43. Greg gregrob 10.24 @ 132.3 1.42 60 3540# 355 LT1 13.6:1 Comp E85, Hydro Roller, 21* trickflows LE ported, 24X, TH-400, S60, PTC Converter 200 hit 7500 DA
  44. Glenn Coates-10.27@132, 95 Z28 M6, 383 LT1, Canfield heads, solid roller, 200 NX shot
  45. Skinnies-10.28@129.3, 1983 Rx7, lt1 with heads/cam, th400, 4.11's, 100 shot, ~2400#
  46. THADD-10.35 @128mph, 97 Camaro, 383 LT1, TH350, 100 shot
  47. Jason Spasoff (lt1camaroman93)-93 Z28 10.41@131, 383 LE LT4 Heads, Custom SR cam, TH350, stock 3.23, 100-250 shot, 3200lbs
  48. Mike Norkavage-10.41@131.58, 95 Z28, 383, AFRs, 200 shot, 10 bolt
  49. BOLO-10.44@130.05 1.53 94Z28, Stock shortblock, Speed Inc H/C/I, Vig3600,4.10,NX150
  50. Nick Eggers (xrambbc) 10.46 @ 129 1.511 60' stock long block 15 psi single turbo
  51. 97blkz-10.47@128 396ci LT1, GM LT4 Heads/Intake, 3200 vig, 3.73's, MT Slicks, 150 shot, 3500lbs
  52. Charles Obstfelder "Chased"-10.48@131, 355 RGR heads/cam, 200 shot, 4$60, 12 bolt, 3770#
  53. WannabeSS-10.57@133 1.65 60', 96 SS M6, LE h/c, golen 383, spray
  54. Darrell (n2ocamaro)- 10.58@124.5 1.42 60' 383, LE heads, hyd. roller, th400, 9", 325/50 DR's, estimated 3500-3600lbs, 150 shot.
  55. C Man -10.59@133.53 w/ 1.52 60', 95 Z28 A4, 383/Nitrous/3740lbs
  56. LT1nitrouZ-10.63@128.9 94 Z 383, CC306, 10 bolt, 175 shot
  57. SPRAYED Z 10.68@123 1.42 60ft 94 z28 Bone stock Long block, Cam Only 4l60e 3400 stall, 3.23 gear 200 shot
  58. Z-RATED94-10.75@125mph, bolt ons, LE heads, Joe O. 222/226 cam, 140shot, stock shortblock, trans and 10 bolt.
  59. Skinnies - 10.80@127.8 w/ 1.56 60, 1996 Formula a3, 355 STOCK heads/cam/intake/TB, 3500lbs, single T76
  60. Joe Miller (joeZ96) 10.801 @ 124.89 1.520 60', stock shortblock, LT4 Hotcam, LE2 H/I, FLT Level 5 4L60E, Yank SS3600, Moser 12-bolt 3.73, Nitrous Outlet 150 shot, full weight
  61. 93v8clone 10.82 @128 on a 150 shot with a 355 c/I on a.f.r 210 heads and a 4k stalled auto
  62. Tom Foolery---1996 Impala SS 10.86@124 1.55 60' LT1 4L60 3.42 17"radials 4600lbs. 400 shot
  63. Chris Jones-10.88@128.06, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/150 shot/3220#
  64. Mike Comp T/A-#57-10.89@128, stock LT1 bottom end/cam, LT4 heads, 3000 stall, 3800lbs
  65. Jon Beam(silver95)-10.914@121.90, '95 Formula, stock engine w/Procharger, 3400#
  66. Miles Gosser 10.95@123 with a 1.57 60ft. Full weight 1994 camaro w/ 396 LT1, and a 100 shot.
  67. Whitemike03911 11.06et 124.89mph 1.67 60ft 396 lt1ported stock heads and intake, 100 shot, e85
  68. Kryckter-11.0@128mph, 97 TA, 355 LE1.5, 200 shot, 3600lbs, 3300ft DA
  69. Mr_Bond-11.10@123.15, 93 Z28, 230/236 Cam, PI 3000 Stall, TNT 150 Shot, Bolt-ons, 3.73s, 3665lbs
  70. Vaders94-11.174@123.91, 94 Z28, 355 LT1 11.1, JOE'O cam/LE2 heads, TH-350/3500 stall, 3.42's, 100 shot, 3500lbs
  71. Frank Staton (HVYSS) 11.19@118.9mph - 4300lb race weight, .040" over LT1, LE2 Heads, GM847, 4.10, 28x10.5, 4L60E, 3500 PTC, 150 shot
  72. Travis (TravisMcgill2000) 94 ta full boltons beside ewp, 3.42 gear, 3800 stall 11.20@120 1.61 60ft 150 shot
  73. Shawn Ferris (3rgden92maro)-11.22@120 (1.56), 95 Formula, LTs,TD's, Th350, 4k Stall, 2860#
  74. Rudy(96Lt1m6) 11.33@117 1.6 60' SLP lid, 1.6rr,4.10s,tune,LTs,2.5"X-pipe. Gear bangin s.o.b.
    150 shot NX shark nozzle.
  75. Blownbird355 11.35@121 w/1.57 60, 94 Form, A4,All forged,S-trim 9.5#, 1 5/8 header,3500 Stall, AI 190's, 3700#
  76. Sweetred95ta-11.33@118 w/1.53 60ft. LT4 Hotcam kit, bowl blended stock castings, 2.0/1.56 valves, K&N CAI, 3.42's, 3600 Vig nitrous converter, stock suspension, 100 shot NX, cut out, mail order tune.
  77. BUILT LT1-11.34@125, 94 Z28 A4, 383 LT1, AFR 195 race readies/Comp 503 cam, 3.42's, 150 TNT Nitrous
  78. daniel6718-11.3@118, 94 Z28, cc306, 3200 stall, 3.73, 100 shot
  79. C.J. Geibe (kolorzcars) 11.46@ 118, 1.71 60' ported heads, zz409,longtubes, auto,3.73, 3000stall, nitto555, ported intake, 80hp of nitrous
  80. Brian (3rdgenvert) 11.53@116.28 92 RS Vert. LT1/HotCam/Stock Heads/Nitrous Outlet 150 Shot.
  81. Jason Muchmore-11.5@119, 97 Camaro, 383, 100 shot, stall, 3.73's, stock suspension, drag radials.
  82. ZEX-Z-11.59@119, 94 Z28 Convertible A4, 4.10's, tune, Longtubes, 150 shot
  83. 1/4 Kyle Hash (SexyTransAm)- 11.60@116, 1.60 60' 95 T/A stock long block, cc503, bolt ons, 100 shot
  84. cgperformance1320 11.62@117.4 1.57 60'-96 z28 a4, m6 rear, shorties, true duals, free mods, 150 shot
  85. speed_demon24 11.68 @ 125 ported heads / GM846 cam boltons 3600# M6
  86. blackz6sp-11.72@115.83, 95 Z28, A4, Stock LT1, 3800stall, 150 shot
  87. 93v8clone-11.772@115, 94 z28, cc503, 3500 stall, spohn rear susp, full exhaust, n/x stage 2 wet kit
  88. David Stegall-11.78@123 w/ 2.08 60ft 97 z28 M6, Bolt-ons/200 shot
  89. biggrif 11.849 w/ 1.69- 60' @ 112.5 mph..."Pretty Much Stock" with bolt-ons with a 150 shot
  90. Mike Stevens-11.89/119mph 1.90 60ft, 1997 m6 cam'd/100shot, bolt ons, 12 bolt
  91. camzaro28-11.9@115, 97 Z/28 A4, bolt ons +150 shot +2200 D.A.
  92. ToxicFormula-11.913@113.89 stock internals LT1, full interior, MT Radial, 100 wet shot, bolt-ons, 3.73 gears, CPT race built 4l60E, 3200 stall, PCMforLess tune, Suspension.
gregrob's Avatar
[+] THE NATURALLY ASPIRATED LIST:
  1. Joe Overton, 9.34@146.8 , 388 ci Lt1, th400 1.24 60 ft. (footbrake)
  2. 9.50@139 (1.24 w/rear wheels), 94 TA 383 LT1/Ai TFS 215 cc race port heads/Pro Ram intake/ FAST computer/Ed Wright tune
  3. 9.606 (1.319) 68 SS Camaro 396 LT1, PG, Dart 180cc Pro1s, Super Vic, Alcohol Injected, 2115lbs
  4. Mike V quik95lt1 - 9.74@138.36 w/1.31 60' 385ci, AI TFS215cnc, AI SR Cam, TH350, 3320lbs N/A
  5. Carlos Saberbein, 9.81@136 , 390 ci Ltx, th400 1.33 60 ft
  6. Ed Wright-9.91@136.51, 96TA 4L60E, 383" LT4 heads & intake/NA/3250lbs
  7. Dave Norquest "N20Dave" 9.98 @ 137 1.47 60' naturally aspirated, manual trans 396 SB2.2headed LT1 SR 28x10.5W's 3730lb raceweight.
  8. Glenn Waguespack-9.98@128, 65 vette, 383 eagle light weight bottom end, home ported LT1 heads, Solid Bullet roller cam, Ported LT1 Intake
  9. Brady Matysek (roadtrip120)-10.075@135.63 (1.48), 94 Z28 M6, 385 LT4, Dart CNC Pro 1, Solid roller, 3240 lbs, 1550ft DA N/A on E-85 "Fastest N/A 6spd"
  10. Taner-10.09@136.37, 1.42 60' 3575# N/A 96 SS 399ci Harshaw Racing Engine, Full BMR suspension.
  11. joelster -10.15 at 133.65, 400+cube LT1, AFR227's, 4500 stall, solid roller, pump gas, 3040lbs
  12. Tony Pezzino 10.20 @ 133 mph 398 ci LT-1 3280lbs 2006
  13. Mike Acton mdacton 10.23 131 mph 383 LT1 ported stock heads carbed
  14. 95 Formula-10.39@131.6, 95 Formula M6 355, stock crank, eagle rods, ross pistons. 12.5 cr, Ported GM LT4 heads, ported/welded lt4 intake, Cam motion solid roller, 25x/26x@50, 3300 ish race weight.
  15. Bunny Mabile-10.56@124, Late 80's Firebird, LT1, mild ported heads, Hyd Bullet roller 230@.050, 3200Lbs, 750 holley
  16. FASTFATBOY-10.58@126,94z CPT 4L60E, solid roller 383 LT1/NA/3600lbs pumpgas, drag radials
  17. Dave Jones-10.62@127 96 Z28 383, N/A, 3450lbs
  18. Larry "LS1 SPEED" 1/4 et - NA - 10.62@126mph 1.41 60ft. 396ci, HR, stock ported heads/intake, FLT 4L60E, 3.73, Yank SS3600 / 3380 #'s
  19. Josh Laitner (96LT1355z28)-10.68 @ 129.5, 1.57 60', N/A 385, 96 Z28, M6, AI TFS, LE SR, MWC 9", Holley EFI, 3400#
  20. Mystery Bird 10.78 @124 1.46 60ft, 381 LT1, 4L80E, 3450lbs DA 500
  21. Stephen Ertel (Wicked94Z) - 10.80 123.5 1.48 - 389ci, 13.2:1 on E85, Hydraulic Roller, Stealth Ram and AFR 210s, TH400 8" Converter.
  22. Joe Spena - 10.82 @ 124.25 1.43 60' 1995 Trans Am, 383ci LT1, AI ported stock castings, mild HR cam, 4000 stall, 4L60E, N/A
  23. Jeff Stark(Badhawk51)-10.82 @ 121.44mph 1.37 60 3450#, 94 Firehawk, 383, Brodix heads, FLT 4L60E, 4000 stall, 12 bolt 4.10 gears
  24. Troy Scheumann (Zleeper28), 10.965@126.99, 383 LT1, TH400 1.53 60 ft. (footbrake)
  25. Warren Dempsey (The Engineer) 10.977@126.9, 1997 Z28 A4, N/A Golen 396 short-block w/ AFR-195s reworked by Lloyd Elliott, Comp custom-grind SR cam, Kooks headers, 12-Bolt spool/4.30s, 3440#
  26. alan 2000t/a-10.98@123.96, 93 Formula M6 396, callies crank, JRP pistons, Lingenfelter GM LT1 H/I, Hyd cam, 12-bolt, 4.11s, 26" ET Drags, 3350#
  27. bowtienut--10.98 @ 122--1996 Impala SS stock shortblock AI h/c
  28. Jason (chas010) - 10.980@122 1.463 60ft stock bottom end ported heads 503cam 4l60 w3200vig 3100lbs
  29. hvyss--11.01 @ 121--1996 Impala SS 385 ci LT1 AI 200cc H/C/I, TH400 n/
  30. Paul Irvin(tapout911)-11.01@120 95Z, Solid roller 383, ported stock heads, N/A
  31. Ken Anderson-11.02@122, 95 Z28 A2, 355/Cam/Heads/NA/3350lbs
  32. BOLO-94Z28, 11.04@122.18,Stock shortblock,H/C/I,4L60E,4000 stall,4.10 Stock 10 bolt
  33. -PEPE--11.123@124.5, 97SS M6, LME Callies Solid Roller 396, 500 N/A rwhp.
  34. Frank95z-11.15 119.86 95Z28 Bolt-ons/3325/Cam only
  35. Dean Stewart-11.18@120.83 N/A, 94 Z28, 11.6 CR 383, LE3 LT4 heads, BRE 230@.050 HYD, LT4 intake, 58mm AS&M, TH400 2800 stall, 3.73, 3550#
  36. Javier97Z28-11.18@120.33, 97 Z28 A4, 355, LE Heads/Cam, Yank PT4000, Moser 9", 4.11's
  37. THADD-11.20 @119mph, 97 Camaro, 383 LT1, TH350, N/A
  38. ABA383-11.23@121.18, 95 Formula 383 A4, LT1 ported heads, Joe O baby cam, Vig 3600, 12 bolt, 3.73s, suspension stuff...3600ish lbs raceweight
  39. SS MPSTR - 11.241@119.34, 97 Camaro Z28 385 N/A, A3, LT4 ported heads, HR cam, Coan 5000, 12 bolt, 4.10s, 3490 lbs raceweight
  40. TravisA-11.26@119.74, '94 Z28 A4/.060 LT1/AI 200cc H/C and Intake/3.73/N/A
  41. TIMELORD 11.267 @ 117.520 1.475 60 ft on 28inch slicks N/A
  42. Matt94z-11.28@118.21, 94 Z28 TH350, 355/ MTI Heads/Joe O cam
  43. Austin Emry (355z28) 11.35@119.1 LE2 383 3600lbs, 3.73, 3600 stall, 1400DA
  44. Jason Short-11.37@126, 93 Formula M6, NA, 396ci, solid roller, AFRs, stock 10 bolt w/3.73s
  45. Mystery Bird 11.37 @117.94, 1.54 60', 381 LT1, Slipping 4l60e, 3700lbs, 2500ish DA.
  46. Troy Scheumann (Zleeper28), 11.43@124.7 , 383 ci Lt1, T56 1.63 60 ft.
  47. John Trevino (Greaseymec) 11.48@118 1.58 60' NA 383 LE2 292XFI, 9" 3.89, 3600 stall, 26" MT ET Streets
  48. tomcowle-11.481@118.98 1.502 60', 95 Camaro Bolt-ons/Auto/Fuel Injected "Bolt on Record"
  49. Josh Bone (86formula) - 11.53 @ 120 1.62 60' 96 camaro, LE2 Heads/cam, JSPerformance Clutch, 4.30 gears, weight reduction
  50. Lloyd Elliott-11.541@117.4, 383, H/C, stall, 3.42, stock suspension, 3820lbs
  51. John P. (1SlowFormula)-11.561@118.00, 95 Formula A4, Bolt-ons/NA/2835 lbs "Bolt on Record holder Sep/08 - Oct/08, short lived victory"
  52. Michael Popson - 11.69@115.49, '96 Corvette, Stock Shortblock, Trick Flow 185 GenX Heads, Comp 503 Cam, PT4000, 3.73's, n/a
  53. Chris Jones-11.650@118.76, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/NA/3220lbs
  54. AChotrod-11.682@119.12 w/ 1.683 60', M6, LE ported stock heads & intake LE custom cam, Speedinc dyno tune N/A
  55. IrocSS85 11.69 @114.23 on a 1.61 3:42 gears, 383, 3800 EDGE stall, 15" et streets
  56. big dave-11.71@117.4, '94 Z28, Ported stock heads/846 cam/stock bottom end/~3700#
  57. Nick Merrifield-11.79@113.5, 94 Z28 A4, 383
  58. Shon Herron-11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record holder 3/26/06 - 09/21/08"
  59. Matt Brunges (StealthFormula) - 11.713@115.36 (1.56), '97 Formula WS6, Stock Shortblock, LE2 Heads, LE1.3 Cam, PT4000, 3.73's, 3500#
  60. Dan Simpson - 11.82 @ 114.20, 1.58 60', 96 Z28 A4, OBD1 Converted, LT4 Hot Cam, 3000 Stall
  61. c5formula-11.85@120 stock bottom end, le2 package, 3450lb, n/a
  62. James Montigny-11.892 @ 113.00mph, 93 Firehawk, LE2 Heads, LE1HL cam, SS4000, MT ETDRs. -103 DA Full street weight + 275lbs driver.
  63. Colin91Z-11.90@118.4, N/A, 96 z28, 350ci, M6, 10 bolt, ~3500#
  64. Brian Nelson(95Z28camaro)-11.91@111mph, 95Z28, Bolt-Ons Only, 4.11's, TH350/3000stall, 3120#
  65. Dwayne Jennings AKA 96capricemgr 11.935@ 112.83mph 96 Caprice, A4, Advanced Induction 190cc heads and cam, stock shortblock 4100#
  66. NewOrleansLT1 11.97 @ 115 1.68 60ft. Full bolt ons, AFR 180cc heads, Hotcam, 3500 Stall
  67. Tony Quadros (CamaroRacing12)-11.998 @ 111.02mph 1.635 60ft 1/8th 7.588 @ 89.33mph , 95 Z28 A4, Bolt-ons only/NA/3150lbs/Bone Stock Suspension, Stock Gears, Stock Rockers, Stock Water Pump, Power Steering, ABS.
  68. James Hayden (buzz12586)- 12.080@111.81, 95 Z28 A4, CC503, Full Bolt-Ons, SS4000, 3500#, 2400DA
  69. Aaron Guerrette-12.086@113.00, 94 Z28, 383, Hotcam, Ported heads, stock valves, All bolt-ons, 2000 stall, 3.23, 3700#
  70. Prototype007, 12.05 @ 109.41 mph, 95 Z28 LT1, CC305 Cam Only, 4l60e, 7.5" w/ 3.42 gears, N/A
  71. PJ Palmer (strokin93z)-12.1@112, 94 Camaro, LE2 Heads, LE1HL cam, SS4000, MT DRs.
  72. jankie93z-12.1@109 (1.67), lt4 hot cam, headers, gutted and stalled th350
  73. big_t (aka BIGT94z)-12.251@110.22, 96 formula M6, bolt on's, 4:10's, et streets, full suspension, 3200#
  74. Dave Kiel (DLK 1950) 12.26 @ 110.8 LE1 heads Bullet cam,A4,3:90 gears and bolt-ons
  75. Isaac C. (Street Demon2k3/NastyCamd93)- 12.26@110mph, 1.66, Built 355: LE2.2 cam, 4K RPM stall, 3.73, full bolt-on's
  76. SPRAYED Z 12.30@110 1.71 60' Bone stock Long block, Cam Only 4l60e 3400 stall, 3.23 gear
  77. Mikey 97Z M6-12.39@114.27, 97 Z28 M6, NA/Bolt-ons/DIY Ported Heads/CC XE224-236/3470#
  78. Smokedoutz28-12.3@113, 97 M6 Stock Bottom end, Stock heads, 847 cam, Bolt on's
  79. Travis (TravisMcgill2000) 94 ta full boltons beside ewp, 3.42 gear, 3800 stall.... 12.3@108 1.59 60ft na
  80. The Big Show-12.40@115, 93 Z28, 385 w/Dominion 32 Valve Heads, Custom Cam, Single Plane, Complete Suspension, 9", Coan TH-400 w/3000 stall, 3400#
  81. 95ztrey-12.48@111.63, 95 z28, N/A le1 heads, Le2 cam, full bolt ons, 3400#, 6700DA
  82. RealQuick-12.5@114mph, 95 Z28, M6, H/C
  83. Psycho_Teddy-12.572@104.27, 94 Z28, A4, 383(Forged Bottom End)/LT4 Hot Cam, Spohn Suspension
  84. Matt Hyde (OddballLt1)- 12.604@105.7 1.66 60' Full exhaust, 3600 stall and 3.73's, 3140#
  85. Michael Taylor (LT1Mike) -97m6 full Bolton's w/ heads/rockers 12.6 @110 on street tires.
  86. (96Silverram)-12.61@109 (1.89), 96 WS6 M6, 350 LT1, Stock heads, Stock cam, bolt-ons, 3600 lbs, 1100ft DA N/A
  87. Michael Taylor (LT1Mike) -97m6 full Bolton's w/ heads/rockers 12.6 @110 on street tires.
  88. Mike English (slowv696)-12.74@109, 94 Camaro, M6, LTs, LM1, CC304, 4.10s
  89. Shawn Ferris (3rdgen92maro)-12.75@106, LTs,TD's, Th350, 4k Stall, 2860#
  90. Matt Plotkin (coolmanvette75)- 12.93 @ 106.4 1.9 60ft', 94 Z28 M6, LT's, True Duals, 3.73s, Moroso CAI, UMI Adj. Torque Arm, Eibach Drag Launch Springs 3566 Race Weight
  91. Rudy(96Lt1m6) 12.98@106 1.93 60' SLP lid, 1.6rr,4.10s,tune,LTs,2.5"X-pipe. Gear bangin s.o.b.
  92. Phil D'Avanzo (zlicious94)-13.003@107.44, 94 Z28 M6, 133k stock motor, Boltons, tune, tru duals
  93. 1slo_camaro 13.01 @109 383, LT4 hotcam, 58mm TB, Pacesetter mids, open v6 rear
  94. Joe Newcomer (2XR95Z28)-13.08@102.63, 95 Z28, Stock Internals, 3200vig, CAI, Exhaust, Full weight
  95. Travis Spence (tspence45)-13.205@105.55, 94 Z28 M6, LS1 lid conversion, LT's, TD's, DR's, MadZ28 tune
  96. 96lt1m6-13.35 105.20, bolt ons, 3004' DA
  97. cgperformance1320 13.51@103 2.0 60'-96 z28 a4 m6 rear shorties true duals free mods n/a
  98. (93z28joel) 13.60 @ 101MPH 1993 z28 A4, stock with 175,000 Miles
Old Dec 17, 2009 | 09:49 PM
gregrob's Avatar
[+] N/A 1/8th mile only
  1. Wicked94Z- 7.01@96.8mph 1.49 60', 94 Camaro Z28 389ci TH400, Ported AFR210 heads, LT4 Manifold, HR Cam, Continental 5600, 9" w/ 4.71s.
  2. Austin Emry 1/8th mile N/A 7.09@95.89mph 1.55 60ft LE2 383 A4
  3. Tracy Evans-7.145@98 1.62 60', 95 Z28, 355, stock crank, injection and pcm. A3, 12 bolt, 3420#
  4. Darrell Popham (n2ocamaro)-7.32@94 mph (1.60), 383, LT1 ported heads/intake, custom cam, th400, 9", drag radials.
  5. OVA1 7.47 @92.59 1.65 60' - '96 LTx Z28 396 Performabuilt Lvl 3, Ported AFR 195s, SS3600 Dana60 Spooled 5.13s.
  6. Miles Gosser 7.63et, 1.64 60ft, @90mph, 1994 z28, N/A 396 w/ stock intake,trueduals over the axle, full weight car, TH350 tranny, 17" wheels
  7. Kyle Hash (SexyTransAm)- 8.01@85.25 1.76 60'-, 95 T/A, stock long block, cc503, headers, 3200 stall, untuned
Old Dec 17, 2009 | 09:50 PM
AChotrod's Avatar
Thanks for taking it over!!!
Old Dec 17, 2009 | 09:52 PM
Speed Density's Avatar
hashtagBMW
Thanks to gregrob for taking over the list!
Tony.
Old Dec 17, 2009 | 09:55 PM
AChotrod's Avatar
What is this **** mister
1993 Camaro Z28 - For Sale $10,000
398ci LT1 on two kits.
Old Dec 17, 2009 | 10:02 PM
hashtagBMW
Time to move on; time for a Viper.
Old Dec 17, 2009 | 10:05 PM
AChotrod's Avatar
Cool and not cool at the same time. lol
Old Dec 17, 2009 | 10:26 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
i need an updating..... 8.97 @ 155.23 mph n2o - fuel injected
10.09 @ 136.41 mph n/a
Old Dec 17, 2009 | 10:32 PM
gregrob's Avatar
Ok, updates complete as far as I can tell.
Post in this thread or PM me for corrections / updates.
Old Dec 17, 2009 | 10:35 PM
gregrob's Avatar
Taner you should be updated. mph is a tiny bit different than you posted in the other thread though?
Old Dec 17, 2009 | 10:48 PM
Ken95Z28's Avatar
Talking
New time for me is 10.62@127
Still a LT1 block and Heads just about everything else has changed.
Old Dec 17, 2009 | 10:57 PM
Z-RATED94's Avatar
Same here, THANKS!! Also, a thanks to Speed Density for taking care of it in the past.
Old Dec 17, 2009 | 11:09 PM
gregrob's Avatar
I dont see you on the list.
Write your time out in the format above and specify N/A or power adder please.
Old Dec 17, 2009 | 11:10 PM
gregrob's Avatar
Thanks guys. Glad I can help out in some small way
Old Dec 18, 2009 | 10:55 AM
vtec's Avatar
Resident Racing Jerk
i need an update as well-
Old Dec 18, 2009 | 04:07 PM
BADHAWK51's Avatar
Looks like you have Brady Matysek (roadtrip120) on there twice and I'm not in the right order Badhawk51 should be up a few spots. NA list
Thanks Jeff
Old Dec 18, 2009 | 06:50 PM
gregrob's Avatar
Thanks for the input guys I'll take care of it
Old Dec 18, 2009 | 07:45 PM
BOLO's Avatar
On the N/A list,---Mike CompT/A #57 10.89@128--- Is that on N20 run? stock bottom end. I thought I saw that same time on another forum stating that run was on 150 shot? But, if thats an all motor pass on stock bottom end, hey thats one hell of a motor!!
Oh, thanks for the update.
Old Dec 18, 2009 | 09:41 PM
BADHAWK51's Avatar
Ok looks like you took care of Brady now I just need to be moved up a few spots.
Jeff Stark(Badhawk51)-10.92@121.44, 94 Firehawk, 383, Brodix heads, FLT 4L60E, 4000 stall, 12 bolt 4.10 gears
