Weird Missfiring Issue
Old Dec 25, 2009 | 07:30 PM
transamws6_97's Avatar
also i just hooked up a multimeter to my drivers side wires (gotta disconnect the passenger side from the opti then ill do those) but right now the readings im getting are
#1 450 ohms
#3 200,000 ohms
#5 600 ohms
#7 2,000,000+ ohms
Old Jan 5, 2010 | 05:43 PM
ok put new taylor wires on and new ngk plugs and new o2 sensors since all of them needed to be replaced anyways but....still having a misfire. While driving i had it read the misfire code and it said cylinder 8 but when i parked it in the driveway and sat there it changed to 0300 which is random cylinder misfire....will check the coil for continuity test. is there any way to test the icm? looks like i might be getting a new opti....
Old Jan 6, 2010 | 12:41 PM
WhyHelloOfficer's Avatar
Where/how is the missfire?
Some assinine questions --
Are you positive you hooked up the wires correctly from the opti?
My first time swapping plug wires following the hayne's manual, it was backwards. There are numbers on the opti to the corresponding cylinder.
With the wide range of resistance your plug wires came up with, were any of them burnt/cracked?
Have you resolved or made sure the new plugs were installed properly and haven't been burned/cut?
Old Jan 6, 2010 | 05:29 PM
yeah the wires are hooked up correctly i did them one at a time and followed shbox diagram. (never knew there were numbers on the opti lol)
i didnt notice any cracking except in the boot of one of them but i think that was from me taking it off and on one of the wires i remember seeing a lil bit of white on the outside of the insulation from where it was near a header but i went from otvc to stock route so none are near the headers now.
Old Jan 7, 2010 | 04:40 PM
just went to the dealership to pick up a few lil parts that i ordered for misc things and got talking to a technician there and he suggested putting fuel stabilizer in the gas so im gonna let it sit over night and if that doesnt fix it ill take it down and hook it up to the tech2...im still putting money on the opti though
Old Jan 9, 2010 | 11:37 AM
ok so its a cylinder 8 misfire i can tell from the code and because it sounds just like one cylinder is not firing so im gonna swap the 6 and 8 cylinder plug to check and see if i have a bad plug and double check and make sure the wires are clicked all the way in the opti..also i noticed the small loom running along the passenger side shock tower was burnt into...not the large one but the smaller one and it looks like it just goes to a 4 wire connector. does anyone know what the loom is for?
