Weird Missfiring Issue
But I don't know if it's because I don't have my car tuned for the cam I have or if I need to check my wires or plugs. I know the plugs I put in were probably from 1994 or something.
onto the problem
okay right now i'm in the process of taking my plugs out...some thing i have noticed is all the drivers side plugs are completely covered black while i've pulled two passenger side plugs so far and both of them are not completely covered the electrode is still white and the ground is still clean where it sparks. I'm thinking maybe this has something to do w/ the o2 sensor?
With the plug wires off, put a little bit of dielectric grease in the plug wire boots, this will help with the connection, plus to keep moisture out of the boots.
What brand were the O2 sensors you replaced? If they weren't AC Delco, you might need to go get some AC Delco sensors. It seems the Bosch O2s you get from your local DAP typically give people fits on the LT1.
If it still drives like crap, then it is definitely ignition related.
