how well do u guys like ur hooker supercomp headers?
Old Dec 20, 2009 | 08:26 PM
xdanny510x's Avatar
Default how well do u guys like ur hooker supercomp headers?
just picked up some LT supercomps from a member on a different forum.. and they look in pretty good condition.. How the fitment on these? and what are some good gaskets to go along with them as well as header bolts and what size i
Old Dec 20, 2009 | 08:47 PM
brynnda's Avatar
these are my fav headers, only type ill run on future cars
Old Dec 20, 2009 | 09:22 PM
RacingTiger03's Avatar
The only problem I ever had on mine was the slip fit on the driver side for it to clear the steering knuckle, and the knuckle safety catch rubbing on the 3rd primary. Bent in the safety catches about 1/2", and used some copper sealant on the slip-fit to cure that leak. Don't forget to tighten down your bolts or get lockers.. do it 1k miles later and forget it (wish I had and so did the cars next owner). I can't comment on the install as my engine was out anyway *shrug* this was on a 94 Z28.
Old Dec 20, 2009 | 09:26 PM
BizZzatch350's Avatar
Moderator
I had no issues with mine, we've installed them twice. I used Felpro 1406 Header Gaskets, they seem to work well. Mine cleared both times with out any issues, the second install was pretty easy since we had done it before, unbolt the motor from its mounts, jack it up as high as it'll go and install them from the bottom.
Old Dec 21, 2009 | 09:40 PM
xdanny510x's Avatar
how much power should it be adding along with a true dual loudmouth set up? Im fairly new to the lt1 crowd.. alwayz owned ls engines.. and they alwayz put a smile on my face
Old Dec 21, 2009 | 10:49 PM
Mighty Whitey's Avatar
I love my hooker LT's.. aside from when I pulled the motor from the car, I've never put gaskets on the car in almost 5 years since I installed them.
fitment was great, and I've yet to have a problem with the slip-fit on the #1 primary leak.
the only thing I dont like is the 3-bolt flange at the collectors. they never did really seal up "perfect" and they're a pain in the *** to tighten up.
oh yeah, and my y-pipe seemed like it was about 1" too far apart for the collectors. took a little "persuasion" when bolting on the y-pipe to the collectors
Old Dec 22, 2009 | 07:52 AM
James Montigny's Avatar
Same here; I cut mine off and used 3" wide band clamps instead.
Also welded my slip-fit.
Old Dec 22, 2009 | 08:40 AM
danhr's Avatar
hated mine. slip fit primary always leaked. 3 bolt flanges suck. fitament was good though.
Old Dec 22, 2009 | 10:21 AM
tbag_skywalker's Avatar
I like everything about my SuperCompLTs especially the fitment-- with the exception of that stupid #1 slip fit primary.
Even with the ultra copper sealer on it, it has a very small leak.
Depending on how good your tune is, you'll probably gain around 30-35hp with LTs and true-duals.
Old Dec 22, 2009 | 02:16 PM
xdanny510x's Avatar
I don't know if I wanna tune it..just yet
Old Dec 22, 2009 | 02:48 PM
slomarao's Avatar
I would tune the car.
Old Dec 22, 2009 | 05:23 PM
At least a mail-order tune.
The last thing you need is to be running lean at WOT.
Old Dec 22, 2009 | 07:26 PM
xdanny510x's Avatar
How much are mail order tunes going for now a days?
Old Dec 22, 2009 | 07:58 PM
$125 http://www.madtuner.com/index.php?pa...id=26&vmcchk=1
$350 http://www.fastchip.com/94-New.htm
Old Dec 22, 2009 | 10:40 PM
xdanny510x's Avatar
has anyone used fastchip?................. i was thinking about having it dynotuned locally at a shop but im worried the 195k motor will go boom.. even those the motor sounds good oil pressure is good and stuff
Old Dec 22, 2009 | 11:11 PM
Ed's been tuning my cars for many years.
No matter how how odd the setup, he's got it right every time.
Nice guy, very sharp and he has more technical resources at his disposal than any tuner I know.
Ed also has a very dry sense of humor and a nack of being brutally honest.
We get along great
He's not the cheapest out there, and there's a very good reason for that.
